susp. swap to itr for crx..how?...
what do i need for this swap...reason for this is i want itr rims on my car and the four disk brakes...is there a link that any of u folks know of....TIA
You will have to swap all of the ITR suspension parts including the hubs. The front suspension is actually a piece of cake and bolts right on but the rear suspension will require the ITR trailing arm which won't bolt right in. Using the ITR suspension will change the CRX's track as well..
Unless you can find used ITR suspension parts for a good deal and in good shape I do not recommend this swap. It's a bitch to find these parts..
Option 2.
You could use EX steering knuckles (to fit the ITR calipers), use Prelude VTEC rotors (redrill 4x100) and use 4-5 lug adaptors (to fit the rims).............
Option 2.
treeafodo
Nov 19, 2013 03:22 AM
