2001 GSR w/ Koni Yellows and Eibach Prokit... Post install Pic
Old Dec 9, 2001 | 11:00 PM
5-SpeedFreak's Avatar
New User
Default 2001 GSR w/ Koni Yellows and Eibach Prokit... Post install Pic
Pic of my car after install of the Yellows and the Prokit...
Before Install
After Install
[Modified by passion4healing, 8:58 AM 12/10/2001]
[Modified by passion4healing, 9:10 AM 12/10/2001]
Old Dec 9, 2001 | 11:03 PM
Mario's Avatar
Default Re: 2001 GSR w/ Koni Yellows and Eibach Prokit... Post install Pic (passion4healing)
No....I'd rather be snowboarding!
Old Dec 10, 2001 | 05:51 AM
YumYumRoLL's Avatar
is that as low as you can go?
Old Dec 10, 2001 | 06:44 AM
Slick GS-R's Avatar
Default Re: 2001 GSR w/ Koni Yellows and Eibach Prokit... Post install Pic (mr clean 4dr)
they still prolly have to settle........
Old Dec 10, 2001 | 07:20 AM
OneThirtyEight's Avatar
Default Re: 2001 GSR w/ Koni Yellows and Eibach Prokit... Post install Pic (Slick_GS-R)
Eibach pro-kits dont "settle". They are as low as they get after you get them on, they may have to even out, distribute the weight evenly, but that should only take a few min. of driving.
Old Dec 10, 2001 | 08:10 AM
Slick GS-R's Avatar
Default Re: 2001 GSR w/ Koni Yellows and Eibach Prokit... Post install Pic (97blackteg)
you sure about that?????? is that what eibach says?????? if so that's pretty cool
Old Dec 10, 2001 | 08:50 AM
mikeSONICGSR's Avatar
That looks sweet, I cant wait to get mine!
Old Dec 10, 2001 | 09:19 AM
deviant94ex's Avatar
New User
Default Re: 2001 GSR w/ Koni Yellows and Eibach Prokit... Post install Pic (mikeSONICGSR)
which spring perches do you have the pro-kits mounted on? i like that drop.....it look perfect.....nice work, nice car
CHRIS
Old Dec 10, 2001 | 10:52 AM
New User
Default Re: 2001 GSR w/ Koni Yellows and Eibach Prokit... Post install Pic (cotton_lix)
Thanks for the feedback! I think the car looks great after the install
I have them installed on the middle perch, as recommended by Koni. The most important thing for me was that the camber was going to be in spec. I am in spec on all four corners without a camber kit.
This was a performance mod more than it was a mod for looks. I took a high-speed run throught the canyons on Saturday. The suspension is dialed in and the car handles really well! I still think the stock Michelins are garbage, but I was more impressed with them after the install of the shocks/springs. I no longer have a problem with understeer under speed and the car is VERY predictable! Sweeping rights that I used to be nervous about going at 60, I can push through them very well at 75+ WOT...
Koni and Eibach get my vote...
Next mod will be a Type-R Anti Sway.....
I can't wait until my first AutoX
Old Dec 10, 2001 | 11:54 AM
Stephen's Avatar
VERY nice.
Not that I don't know what you're going through
A 22mm rear sway will complete the package!
Old Dec 10, 2001 | 12:18 PM
exquivical's Avatar
New User
yea, a drive around the block or letting it sit for a few minutes and it will settle.
Old Dec 10, 2001 | 11:04 PM
degradated's Avatar
New User
Default Re: 2001 GSR w/ Koni Yellows and Eibach Prokit... Post install Pic (exquivical)
damn, Marc....you already take those canyon turns fast enough. I don't want to be in the car with your new suspension set up now.
Old Dec 11, 2001 | 06:18 AM
MAGSGSR's Avatar
YOUR RIDE LOOKS GOOD AS HELL,I HAVE THE SAME SETUP AT HOME,SOME DIRT BAG PIECE OF **** STOLE MY CAR THE DAY BEFORE I WAS HAVING THEM PUT ON THOW.DEATH TO CAR THIEVES!!!!!!!!!!!!!!!!!!!
Old Dec 11, 2001 | 09:46 AM
gsrapper's Avatar
New User
Default Re: 2001 GSR w/ Koni Yellows and Eibach Prokit... Post install Pic (MAGGSGSR)
thats nice but i have comptech springs and koni's but i put them on the lowest perch and i don't hit anything all I had to get was a front camber kit and put washers in the back, if your going to put on the oem body kit then stay with that setting, when I wash my car it looks so good that 2.25 inch drop in the front and about 1.8 in the back, need a digital camera
Old Dec 11, 2001 | 08:34 PM
proton's Avatar
So that is a 1.75" drop, right? That looks very nice.
I was thinking of getting the KYB AGX's and some H&R sport springs. The KYB's are only warrantied up to a 1.5" drop, or so I have been told. They are a lot cheaper than the koni yellows and I was wondering if any on you have had any experience with them.
Old Dec 11, 2001 | 09:00 PM
StinkyTofu's Avatar
Default Re: 2001 GSR w/ Koni Yellows and Eibach Prokit... Post install Pic (proton)
i think thats a 1.4 inch drop...a 1.75 inch drop is with the H&R Sports.
Old Dec 11, 2001 | 09:23 PM
proton's Avatar
Default Re: 2001 GSR w/ Koni Yellows and Eibach Prokit... Post install Pic (B-18C1)
Oh...Well that's is plenty for me. So the Eibach Pro's give a pretty good ride, eh? I'll definitely consider those over the H&R's.
Old Dec 12, 2001 | 01:14 PM
New User
B18C1, is your camber in spec with the extra .25 lowering? I was RIGHT at the edge of being in spec without a camber kit....
Old Dec 12, 2001 | 01:44 PM
Allstar's Avatar
New User
you should go a little lower imo, i had koni's with race springs and i had the spring perch at the lowest setting and flipped the perch upside down so it was like a 6th setting. the ride was really good and the car sit perfect, it looked really clean and i never scrapped.
Old Dec 12, 2001 | 01:56 PM
proton's Avatar
Oh, sorry if I mislead you. I haven't lowered my car yet. I'm looking to do it this spring. I'm leaning towards the Eibach Prokit springs now, since the lower only 1.4" and it looks great on your car. I was worried that it wouldn't get rid of enough wheel gap but I didn't want to go lower than 1.5" because I don't want to fork out the cash for koni yellows. If I drop less than 1.5 then I can use KYB AGX's. I've heard mixed reviews about them on the 'net but most of the auto-crossers around my town run KYB's adjustables.
Old Dec 12, 2001 | 02:02 PM
StinkyTofu's Avatar
i don't think my camber is in spec in the front cause it doesn't pass my "visual inspection". The rear "looks" ok though. I'll be getting a camber kit whenever those tires die. i hate those stockers grrr >
Old Dec 12, 2001 | 02:03 PM
New User
Proton, I've got a friend that just spent a fortune on his suspension, Ie: drop spindles and the like... He uses KYB AGX coilovers and loves the setup.
B18c1, My motivation for getting the Prokit is that I didn't want to have to use a camber correction kit. I don't want to modify the stock suspension geometry more than i have to. When driving like I do, I don't want to have any "Bump Steer" which, camber kits produce.
Didn't you get your car aligned after the install of the springs/shocks? If you did (and should have) there is a report of your camber settings, and if any correction needs to be made.
[Modified by passion4healing, 3:05 PM 12/12/2001]
[Modified by passion4healing, 3:07 PM 12/12/2001]
yikes99
Suspension & Brakes
Jul 10, 2008 12:24 PM
evosix
Suspension & Brakes
13
Jun 30, 2008 10:33 AM
Daniel_san
Sep 1, 2004 06:57 AM
tunerz
Audio / Security / Video
24
Dec 13, 2003 12:29 AM
yangrou8
Jul 29, 2003 09:05 AM
