Axle/Tranny questions
Old Sep 17, 2004 | 10:38 AM
kmf0211's Avatar
Default Axle/Tranny questions
92 Si hatchback -
With the car jacked up, started and put in first - which wheel should be spinning?
My driver side wheel spins fine and the pass. is trying to spin but its not moving
My driver side axle, I think, is making some noise when I'm driving - Kind of like the tire is rubbing on the plastic sometimes, some clicking and etc. I plan on replacing the axle today because a friend told me it was a worn joint. Are those normal axle symptoms or am I crazy?
thanks guys
Old Sep 17, 2004 | 11:21 AM
dohcdelsol93's Avatar
Default Re: Axle/Tranny questions (Si.Hatch.92)
not sure about the spinning tire part there, when my car is up and put into first both wheels spin, posi traction. The clicking and popping does sound like a cv axle. change it before it goes
Old Sep 17, 2004 | 12:45 PM
EK45VTi's Avatar
Hmm. definitely check the axles... maybe they are bent... check the CV joints too... check your wheel bearings...
But it smells to me like you've got differential bearing going bad... I hope I am wrong... I really HOPE SO...
BOOSTED_JDM_DB8
Dec 26, 2007 12:15 PM
timcali69
Aug 7, 2007 08:52 AM
213374U
May 28, 2007 08:38 PM
Elmo1968
Oct 18, 2006 10:18 AM
turbotime
Oct 4, 2005 06:19 PM
