help with excessive tire rubbing need advice
Old Sep 17, 2004 | 09:58 AM
slow motion's Avatar
Default help with excessive tire rubbing need advice
Modified by slow motion at 7:47 PM 10/3/2004
Old Sep 17, 2004 | 10:14 AM
jdm123's Avatar
Default Re: help with excessive tire rubbing need advice (slow motion)
your wheels are to big or if you absolutley love your rims then you car is to low either way you want to look at it.
Old Sep 17, 2004 | 10:23 AM
Jowee's Avatar
Default Re: help with excessive tire rubbing need advice (jdm123)
You have coilovers, so all you should need to do is raise it up. If that doesn't work, jack you car up and turn the wheel left and right all the way and see if the wheel is too wide and rubs against the chassis. If so, get some spacers to fix it.
What engine/bushings/mounts do you have? If one side is stiffer than the other it could contribute to the uneven wear. Make sure you also get a good alignment.
Old Sep 17, 2004 | 10:26 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: help with excessive tire rubbing need advice (ITR 98 1162)
is it possible that the side that is rubbing is set on a softer setting by accident or maybe the spring is absorbing more than it should (possibly a defect)
i don't know how you would go about proving that though
Old Sep 17, 2004 | 10:37 AM
cxSHOE's Avatar
1. roll your fenders alittle more.
2. get +45 offset wheels. +43 may not be enough.
3. raise your suspension up 1/2 inch.
4. realize you cant be too slammed on 16" wheels. thats why most stick with 15" when they lower their cars.
Old Sep 17, 2004 | 10:47 AM
jdm123's Avatar
Default Re: help with excessive tire rubbing need advice (cxSHOE)
golden words those are
Old Sep 17, 2004 | 12:23 PM
SilVaCiVik's Avatar
i'm running 15" 95 GSR's...same problemo still w/the rubbing. =/
blackened02
Honda Civic (2001 - 2005)
Jul 27, 2010 09:19 PM
FOdoFAsho
Honda Civic (2006 - 2015)
10
Dec 25, 2007 08:39 PM
(JON)
Aug 19, 2004 02:33 PM
Bryan-95prelude
Aug 11, 2004 05:41 AM
vietboionfiyah
Aug 20, 2002 05:23 PM
