code 15: ignition output signal
Old Sep 17, 2004 | 08:23 AM
IWearMyKswiss's Avatar
New User
Default code 15: ignition output signal
could bad spark plug wires cause code 15 to come up? reason i ask because my tach is goes nuts and the car backfires and then dies,...i pop the hood,..pull out the spark plug wires and than put them back in,..then i reset the ECU and the car is fine for awhile and then it starts doing it again,..i just replaced the coil about a month ago also
Old Sep 17, 2004 | 08:34 AM
Cnote's Avatar
Default Re: code 15: ignition output signal (2.0 EK)
check dizzy
you might have a loose rotor
Old Sep 17, 2004 | 08:59 PM
New User
any other ideas?
Old Sep 17, 2004 | 09:31 PM
Luserkid's Avatar
Your ignitor is going bad. All that time it takes for you to check the spark plugs gives the ignitior time to rest to start again but then it dies. That **** was happening to me, pissed me off.
Old Sep 17, 2004 | 09:49 PM
ABK's Avatar
ABK
Default Re: code 15: ignition output signal (Luserkid)
Kind of sounds like a bad coil. Secondary winding is prolly ******* up. Or ignitor is messing up.
Bluespower
Feb 15, 2012 06:07 AM
efsedan556
May 19, 2011 08:37 PM
Dc-2Luke
Dec 7, 2009 08:27 AM
EK_vzla
Aug 30, 2004 01:39 PM
importboi22
11
Jun 22, 2004 01:10 PM
