Warranty comming to an end; last service, what to check?
My warranty ends in April of 2005. What things should I get Acura to check and/or replace before my warranty ends?
On my list currently:
- Replace gasket for steering wheel through floor (squeaks right now while turning)
- Window regulator replacement (Acuras suggestion), clean and lube track.
- Lube rear hatch switch (seems to stick sometimes)
I was thinking of having them check and adjust all motor mounts (car shakes at idle, either rough idle or bad motor mounts?).
Anything else? Last time I tested my compression it was good (250+ on all cylinders).
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R »</TD></TR><TR><TD CLASS="quote">oil dipstick tOOb?
squeaky clutch pedal?
Modified by Philly_NBP_R at 1:15 PM 9/17/2004</TD></TR></TABLE>
Exact same 2 things I will need looked at.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThePro »</TD></TR><TR><TD CLASS="quote">I'd see if you could get them to replace the gasket for the brake lights. May not need it, but why not get a new one?</TD></TR></TABLE>
They will not replace it unless there is a problem w/it already. Chris-You warrenty ****** **** me off
twentytwocpb
Feb 27, 2008 01:24 PM
TegRyan
Sep 24, 2005 02:54 PM
redINTEGRAdriver
Jan 9, 2005 04:21 PM
