camber squeek?
i recently put a skunk 2 camber kit on. and it seems like the right side is making squeeking noise... is that normal? i looked and it seems like its rubbing the fender well... but only the right side is doing it. i can hear the squeeks when i drive slow, i probably cant hear it at higher speeds because of the wind.
if it's hitting the fender wall then u got too much + camber. u need to move the camber piece back a little. my cheap dropzone camber kit squeaks a bit. i just spray some wd-40 on it and it solves the problem......for a little while
itsJDMyo
13
Jan 7, 2005 10:40 AM
