Cleaning out the garage lots of stuff everything OBO and some turbo stuff.
More cleaning in the garage. here is some stuff. contact me at turbomouse@gmail.com or on aim at turbols6.
some times i dont get my private messages on this site cause of my nortons anti virus so just email me.
Integra gsr or ls first gear. $OBO
OBD 1 B16 Stock Distributor cap, rotor, and seal, no cracks and the rotor has very few miles on it $OBO
Wastegate dump tube. 38mm flange. just needs to be welded $OBO
stock fuel pressure regulator $OBO
Hurst short shifter 92-00 civic and 94-01 teg used for about 5k $OBO
2 obd 1 ecu covers $OBO
stock fuel filter never used $OBO
Idle air control valve (long one) jdm low miles $OBO
Air intake temp sensor $OBO
2 Evap Purge soleniods $OBO
Map Sensor $OBO
2 oem oil pump seals brand new from honda still sealed. $OBO
Tranny bearing and seal $OBO
1 T3 Manfiold to turbo gasket. 4 35/38 mm wastegate gaskets. t3/t4 oil drain flange and gasket $OBO
Stock ignition coil out of obd1 jdm b16 low miles $OBO
TURBO XS hks ssqv to txs blow off valve adapter and 2 ssqv c-clips and 1 o-ring $OBO
Integra gsr main girdle dowel pins $OBO only 1 has been opened
5 MSD coil wires and 3 coil wire install kits and other misc msd wiring $OBO
JDM starter cable $OBO
JDM B16 fast idle valve $OBO
OBO0 Vtec solenoid $OBO
Honda del sol tail light wiring harnesses $OBO
b series tranny to motor brackets and some other bracket i have no idea what it is. $OBO
Map Sensor $OBO
Lightning Orders
Nov 5, 2004 04:00 AM
