some questions on jun/itr cam combo
Old Dec 9, 2001 | 09:16 PM
itr501's Avatar
Default some questions on jun/itr cam combo
First off, can I run the Jun2 intake cam with ITR exhaust cam combo on stock valvetrain? and is 200 whp realistic for this combo? I hear of stock ITR's pushing out about 180 - 185 through tuning so I would assume this would be possible?
Secondly, can I run Toda B intakke cam with ITR exhaust cam? and what other cams can also work in conjuction with ITR exhuast cams?
Old Dec 10, 2001 | 06:08 AM
SpoonFed's Avatar
Default Re: some questions on jun/itr cam combo (itr501)
awesome ? .... Ask Mike K for the answer....he seems to be the master at this
Old Dec 10, 2001 | 10:53 AM
05 600RR's Avatar
Default Re: some questions on jun/itr cam combo (spoonfed)
If you do a search there was a topic about this a week or so ago.
Old Dec 10, 2001 | 04:54 PM
gsr98vtec's Avatar
Default Re: some questions on jun/itr cam combo (01 ITR 01-0492)
if you run stage 3 jun cam i suggest you get the exhaust cam as welll....i have seen the stage 3 and the itr exhaust cam both and the jun 3 exhaust cam has a huge lobe compared to the itr...also just look at the specs and you can see the difference...
Old Dec 10, 2001 | 05:44 PM
StinkyTofu's Avatar
Default Re: some questions on jun/itr cam combo (gsr98vtec)
i'm looking to buy the Jun stage 3 intake cam and ITR exhaust cam combo in the future. Anyone know if this is street legal and if it will pass smog in cali?
Old Dec 10, 2001 | 06:01 PM
Mike K's Avatar
Default Re: some questions on jun/itr cam combo (B-18C1)
Stock valve train is ok when using the Jun 2 intake cam ONLY. The Jun 2 exhaust cam seems to be a little large for the blue valve springs.
With Jun2/ITR you'll be fine with revving too since the power peaks below 8000.
Old Dec 10, 2001 | 06:10 PM
1fastGSR's Avatar
New User
Default Re: some questions on jun/itr cam combo (Mike K)
I looked at the specs for Jun 2 and Jun 3 INTAKE cam and they both have the same lift, 12 mm. Is that right?
[Modified by 1fastGSR, 7:11 PM 12/10/2001]
iH8RICERZ
Northern California (Sales)
Oct 11, 2005 12:03 AM
scooter
Dec 10, 2001 06:27 AM
gsr98vtec
Dec 8, 2001 11:28 AM
1fastGSR
Sep 7, 2001 08:12 AM
