90-91 corner lights on an 89 - looking for a definitive answer
Old Sep 16, 2004 | 07:53 PM
steronz's Avatar
Default 90-91 corner lights on an 89 - looking for a definitive answer
i have an 89 CRX, and I'm going to the u-pull-it this weekend to pick up a new fender. if i get the fenders off a 90-91 CRX, and I also grab the corner lights, will they work fine? I know how the 89 corner lights attach, but the 90-91s are a mystery to me. searching just confused me more... basically, where do the 90-91 corners screw down? Thanks.
Old Sep 16, 2004 | 09:48 PM
Slammed_S13's Avatar
Default Re: 90-91 corner lights on an 89 - looking for a definitive answer (steronz)
In the 90-91 Civic/Crx Fenders, there is 2 clips that the Corners slide into at the back and a Screw at the top of the light to hold it in place..
Old Sep 17, 2004 | 05:22 AM
steronz's Avatar
Default Re: 90-91 corner lights on an 89 - looking for a definitive answer (Slammed_CX)
so will i need the lights as well?
Old Sep 17, 2004 | 06:42 AM
CRX Toad's Avatar
Can't put 88-89 on 90-91 and can't put 90-91 on 88-89
Old Sep 17, 2004 | 06:46 AM
steronz's Avatar
well that's not true...
Old Sep 17, 2004 | 07:49 AM
spaceman's Avatar
Default Re: (steronz)
if its not expensive give it a try..there are differences between the years...sorry cant help you,cuz i have never done what your trying to do
Old Sep 18, 2004 | 01:04 AM
mikerbike's Avatar
Default Re: (spaceman)
the 90-91 corners slide in like Slammed_CX said. After they are slid in, there is a screw that goes into the 90-91 headlight bracket. The hole for the screw is absent on the 88-89 headlight bracket though. If you get the fenders and corners, you will just have to find a way of holding them from sliding out. I actually have a 90-91 corner on my 88-89 fender. I just have bailing wire holding the whole thing in, no sliders or anything. I am so ghetto, it hurts. Good luck.
Old Sep 18, 2004 | 06:30 AM
steronz's Avatar
Default Re: (mikerbike)
awesome mikerbike, thanks for the reply. looks like i'll stick with finding an 88-89 fender.
Old Sep 18, 2004 | 07:48 AM
CRXBart's Avatar
Yeah you can get any year EF lights to work you just have to change the headlight for the correct year corner. As mentioned before, the mounting screw for the 90-91 is in the headlight bracket. The sliders or screw holes should be matched up too, but aren't really necessary. I have 90-91 lights in my 88 without the sliders no problem, I just switched to 90-91 JDM headlights. Yes my car, that I am talking about is a hatch, but I've done it on a CRX too. I would stay away from the ghetto rigging the light braket though, unless you really don't care.
661rex89si
Aug 10, 2008 06:57 AM
anj_jmv
21
Oct 20, 2007 04:47 PM
B-serious
Jun 1, 2006 05:17 AM
-slow ej-
Jul 21, 2004 08:08 PM
NikoZai
Jul 9, 2002 02:41 PM
