Help lower ball joint removal!!!!
Old Sep 16, 2004 | 06:39 PM
spcrxracer's Avatar
Default Help lower ball joint removal!!!!
ok so i sm almost ready to take out the b16a, last thing to do is disconnect the axles. DRIVers side removes perfect passenger side, went to losen the lower ball joint nut and the whole ball joint spins. the nut doesnt move at all. i tried heating with a torch and everything. i am stuck need some help !!!!!!!!!
Old Sep 16, 2004 | 06:45 PM
crxY-49's Avatar
Default Re: Help lower ball joint removal!!!! (spcrxracer)
put the tires on and drop the car back to the ground. the weight of the car will keep it from spinning.
Old Sep 16, 2004 | 06:47 PM
Synth124's Avatar
two ways i think, either way I don't think is the best.
1) Take some channel locks and compress the lca and spindle with them and that might jam it up.
2)Take a pickle fork and jam it up in there, as if you were going to seperate it. And see if that works. From the sound of it, either way you need a new balljoint because you took a torch to it.
best of luck, my method(s) are that sweet, but hey, they might just work.
Peace
Synth
Old Sep 16, 2004 | 07:03 PM
MonkeyMagic's Avatar
Default Re: Help lower ball joint removal!!!! (crxY-49)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxY-49 &raquo;</TD></TR><TR><TD CLASS="quote">put the tires on and drop the car back to the ground. the weight of the car will keep it from spinning. </TD></TR></TABLE>
do NOT do this... think about it.. if this does make the nut come off, the entire car will come crashing down, pushing the lower control arm onto the inside of your rim.. god forbid you are under the car
instead, place a jackstand under the control arm closer to the bolt
drop the car down easily onto the jackstand and voila.. pressed-in ball joint.
the nut will come off, then jack the car back up (might have to break loose again)and remove the ball joint shaft from the hole in the control arm.
Old Sep 16, 2004 | 09:17 PM
spcrxracer's Avatar
Default Re: Help lower ball joint removal!!!! (MonkeyMagic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonkeyMagic &raquo;</TD></TR><TR><TD CLASS="quote">
the nut will come off, then jack the car back up (might have to break loose again)and remove the ball joint shaft from the hole in the control arm. </TD></TR></TABLE>
Thanks but i just decided to cut it off. I am swapping in a b18c from my OTHER crx so i will just take the parts off of it and put it on this one. I was going to change the suspension between the 2 anyways. Looks like i am doing it ahead of schedule though
Old Sep 17, 2004 | 07:24 AM
tgreaves's Avatar
An impact gun will remove it very eaisly..
Old Sep 17, 2004 | 11:01 AM
dr_latino999's Avatar
Default Re: Help lower ball joint removal!!!! (tgreaves)
You could have just removed the lower control arm from everything and left it hanging from the ball joint, there for saving the trouble of cutting and such what.
ZOMBIEKILLER
Suspension & Brakes
11
Feb 24, 2008 05:51 PM
sky9
12
Jan 8, 2008 01:39 PM
rasinhell
32
Jan 17, 2005 04:57 PM
MarkN929RR
Mar 11, 2004 09:35 AM
pikappaphi
14
Feb 6, 2004 09:15 AM
