*DIY* tilt wheel (non adjustable) for dx civics with out tilt wheel feature...
Old Sep 16, 2004 | 06:30 PM
SuicideSlide's Avatar
Default *DIY* tilt wheel (non adjustable) for dx civics with out tilt wheel feature...
(Pics will be added tomorrow)
If your one of the few unlucky ones to own a 92-95 dx without a tilt wheel you know exactly how crappy it feels to not beable to tilt your wheel up and down. Well Ive found an inexpensive and rather easy way to do this.
Wile completely revamping my car, geeky gambit and I figured out a way to lower the steering column by using washers between the two bolts holding up the steering column.
Once you remove the plastic cover to your steering column, you'll see the 2 12mm nuts threaded over long threaded bolts. Remove those 2 nuts and slide the steering column all the way off. (Being carefull not to strip the bolts)
Now with the column hanging off the two bolts slide a few washers up the two bolts. Once there up check to see if the steering column is at a favorable spot for yourself. Make sure not to go to low, because you still want plenty of thread left to hold onto your steering column. Once your done slide the column back up, replace the 2 12mm nuts and tighten them both. Replace your plastic column cover, and valaaah... lowered steering column.
Old Sep 16, 2004 | 06:32 PM
-Gambit-'s Avatar
Default Re: *DIY* tilt wheel (non adjustable) for dx civics with out tilt wheel feature... (Tur*bLu)
um yea.... but it works..... or something....
but its a very easy DIY if you need your steering wheel lower
Modified by Geeky_Gambit at 4:53 AM 9/17/2004
Old Sep 16, 2004 | 06:33 PM
jdmsiR20's Avatar
*gasp...
my cx is givin' me crap and wont let me adjust either....
pics would be good
Old Sep 16, 2004 | 07:06 PM
dantastic's Avatar
i think the tilt angle is perfect in my CX. i just wish it would telescope in a tad. gonna tray a momo with a shorty hub...
i've heard of ppl successfully swapping in full tilt columns
Old Sep 16, 2004 | 07:29 PM
splitime's Avatar
Default Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">
i've heard of ppl successfully swapping in full tilt columns</TD></TR></TABLE>
Yup, very straight forward. I used an eg6 tilt column, had some issues with the switches bolting on, still a bit tilted, but I've got tilt. Don't forget to get a tilt wheel column cover.
Old Sep 17, 2004 | 09:02 AM
Default Re: *DIY* tilt wheel (Geeky_Gambit)
post whorring now eeeh aaron.... damnit... not only are u 1UP #2 ur like the #2 post on half my new posts....
You ****** ******!!!
BTW PICS UP IN AN HOUR...
Old Sep 17, 2004 | 09:33 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: *DIY* tilt wheel (Tur*bLu)
post pics please, i can only work with visual references
&lt;----retarded
Old Sep 17, 2004 | 10:29 AM
Jonny G.'s Avatar
Sounds like a good DIY... just waiting for pics
Old Sep 17, 2004 | 10:34 AM
JDMisGOOD's Avatar
Default Re: *DIY* tilt wheel (Jonny G.)
Its still not a "TILT" wheel...its still stationary!
Old Sep 17, 2004 | 10:40 AM
3.point.2's Avatar
im gonna have to try this cause i like my wheel pretty low
Old Sep 17, 2004 | 05:11 PM
-Gambit-'s Avatar
now that was a harsh reply andrew, and where are the pics that were promised...
Old Sep 29, 2004 | 08:14 PM
Bense's Avatar
can you raise the wheel with this method or can you just lower it?
Old Sep 29, 2004 | 08:50 PM
-Gambit-'s Avatar
Default Re: *DIY* tilt wheel (thebense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thebense &raquo;</TD></TR><TR><TD CLASS="quote">can you raise the wheel with this method or can you just lower it?
just lower it
Old Sep 29, 2004 | 08:54 PM
Donkey85's Avatar
props to you for the good idea
Old Sep 30, 2004 | 09:46 AM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Geeky_Gambit &raquo;</TD></TR><TR><TD CLASS="quote">just lower it</TD></TR></TABLE>
i'm 6'4", it's already too low.
Old Sep 30, 2004 | 10:45 AM
XoUnKoWnXo's Avatar
i'm 6'4", it's already too low.</TD></TR></TABLE>
I have the same exact problem
Old Sep 30, 2004 | 10:59 AM
chad's Avatar
Moderator
Default Re: *DIY* tilt wheel (JDMisGOOD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD &raquo;</TD></TR><TR><TD CLASS="quote">Its still not a "TILT" wheel...its still stationary! </TD></TR></TABLE>
exactly....
Old Sep 30, 2004 | 11:03 AM
chad's Avatar
Moderator
Default Re: (h23eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23eg &raquo;</TD></TR><TR><TD CLASS="quote">im gonna have to try this cause i like my wheel pretty low</TD></TR></TABLE>
it won't help you if your wheel is too low....only if it sits too high
Old Sep 30, 2004 | 11:22 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: (chad)
my CX doesn't have tilt but my steering wheel sits in a pretty good position for me and I'm 6'
Old Sep 30, 2004 | 03:50 PM
Bense's Avatar
Default Re: (TouringAccord)
is there anyway to be able to raise it up?
Gangified
Sep 10, 2017 04:03 AM
TOO MUCH TORQUE
Suspension & Brakes
Aug 21, 2011 09:29 AM
Itzmy91Teg
Jun 12, 2006 03:39 AM
killa_lude
Jan 26, 2004 07:04 PM
