dyno charts b18c stock block/head almost 200whp
Old Sep 16, 2004 | 12:55 PM
Y2K Si FBP's Avatar
Default dyno charts b18c stock block/head almost 200whp
edit for block pics
leave any input good or bad. blew the motor 3 days later at the track..got alil too greedy
modslist
jdm b18c gsrblock /type R head
skunk stage 2 cams/springs/reatiners/gears/stock valves/mugen headgasket
aem shorty/cheapy 4-1 2.5" collector header/rsr exhaust/kenji 9000 rev limit ecu/vafc/b&m fpr/walbro 190 fuel pump.
baseline:
#4 cylinder
Modified by Y2K Si FBP at 9:32 AM 9/27/2004
Old Sep 16, 2004 | 12:58 PM
Tbone's Avatar
Default Re: dyno charts b18c stock block/head almost 200whp (Y2K Si FBP)
How did it blow? dropped valve?
Old Sep 16, 2004 | 12:59 PM
Y2K Si FBP's Avatar
Default Re: dyno charts b18c stock block/head almost 200whp (Tbone)
strapped slicks on..and dropped exhaust.it blew on the burnout. not even 6000 rpm. and i haven't seen it yet..friend who pulled the head said 2 valves melted to the top of piston. so way lean
Modified by Y2K Si FBP at 12:29 PM 9/17/2004
Old Sep 16, 2004 | 01:30 PM
red civic standard's Avatar
what makes a head stock? no port and polish?
Y2K Si FBP's Avatar
Default Re: dyno charts b18c stock block/head almost 200whp (red civic standard)
well no port/polish
just cams/valvetrain. stock itr valves
run with airfuel:
Modified by Y2K Si FBP at 12:36 PM 9/17/2004
Old Sep 16, 2004 | 02:30 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
sounds like you may have hurt it on the dyno then it let go in the burnout box
Old Sep 16, 2004 | 03:03 PM
NSTY Z33's Avatar
Default Re: dyno charts b18c stock block/head almost 200whp (HOOKUPS)
hmm, find it weird that it blew.
Old Sep 16, 2004 | 03:36 PM
Tbone's Avatar
What are your cam gears set at?
Old Sep 16, 2004 | 03:44 PM
Y2K Si FBP's Avatar
we tried intake/exhaust
+1/0
+2/0
+2/-1
+2/-2
+2/+1
+2/+2
final power was best at +2 intake +2 exhaust
Old Sep 16, 2004 | 04:09 PM
nosturbo's Avatar
Was a burnout really necessary with slicks and only 197 hp?
Old Sep 16, 2004 | 05:24 PM
mrbsponge's Avatar
yeah no matter the HP a slick depending on compound is designed to work in a sertain heat range, just as your street tires are.....(on them look for the temperature rating)
Old Sep 16, 2004 | 05:25 PM
mrbsponge's Avatar
oh yeah, motors always run the best right before they blow up bro.....
to me it looks as if you could have richened it up all the way across the board and been alot safer. i usually keep mine in the 12.5 range just for ***** and giggles
Old Sep 16, 2004 | 07:09 PM
Combustion Contraption's Avatar
That head isnt even remotely close to stock. Very misleading thread title.
Old Sep 16, 2004 | 07:23 PM
Y2K Si FBP's Avatar
Default Re: (LsVtec92Hatch)
once again. there is no port. no polish. no milling/shaving of the head. head casting/characteristics is stock.
sorry i guess.
Modified by Y2K Si FBP at 12:42 PM 9/17/2004
Old Sep 16, 2004 | 09:58 PM
MikeySpec's Avatar
Default Re: (Y2K Si FBP)
Hey dude i love your band!
Old Sep 16, 2004 | 10:03 PM
Then the head casting is stock. Thats like if i put some crazy *** wiseco 14:1 compression pistons in my block and said "stock block" all it has is pistons, rods and scat crank. Sorry.
Old Sep 16, 2004 | 10:20 PM
johnzm's Avatar
no matter still nice #'s
and yes burnouts are nessecity with slicks.
if u can get some pics, i wanna see how it blw up
Old Sep 17, 2004 | 03:35 AM
siR cr-x's Avatar
Default Re: (johnzm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Then the head casting is stock. Thats like if i put some crazy *** wiseco 14:1 compression pistons in my block and said "stock block" all it has is pistons, rods and scat crank. Sorry.</TD></TR></TABLE>
i agree
Old Sep 17, 2004 | 04:19 AM
jdm_ef9's Avatar
Default Re: (siR cr-x)
man that sucks... nice numbers though for your setup.
Old Sep 17, 2004 | 06:36 AM
WAFFLES's Avatar
Default Re: (jdm_ef9)
I never would have thought a 13.8:1 a/f is too lean. I guess maybe real life load had an affect on the engine. Anybody's thoughts on that?
Old Sep 17, 2004 | 09:26 AM
Hybrid96EK's Avatar
Default Re: (WAFFLES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES &raquo;</TD></TR><TR><TD CLASS="quote">I never would have thought a 13.8:1 a/f is too lean. I guess maybe real life load had an affect on the engine. Anybody's thoughts on that?</TD></TR></TABLE>
According to that dyno, that engine was not running lean.. It was running about right where I would tune an NA engine, 13.5:1.
Old Sep 17, 2004 | 10:34 AM
stevel's Avatar
that's what he said, the head is stock. The valvetrain isn't though. Just cause valvetrain isn't stock doesn't mean the head isn't it. i guess it's in the interpretation. To me his setup is stock head but not valvetrain. And "crazy *** wiseco 14:1 compressions" pistons you can still say stock block if it's not sleeved. The block hasn't changed at all. Now if you said stock bottom end but had forged pistons, that's incorrect. Stock bottom end and stock block are 2 different things.
just MHO.
s
Old Sep 17, 2004 | 10:40 AM
I guess you can parse words down to the letter, so to speak, i just think the thread title was a little misleading when i see a gsr with stock block/head pushing 200whp i know somethings up.
Old Sep 17, 2004 | 11:35 AM
if the valvetrain was stock, would you consider the head stock even if it had cams?
Old Sep 17, 2004 | 11:53 AM
stevel's Avatar
Default Re: (red civic standard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red civic standard &raquo;</TD></TR><TR><TD CLASS="quote">if the valvetrain was stock, would you consider the head stock even if it had cams?</TD></TR></TABLE>
yeah, head is still stock. i consider the cams a part of the valvetrain. they actuate the valves. maybe i'm wrong on that one but oh well. as long as it's not ported, stock head. Stock top end is a different thing though.
s
