Trouble!!!!
My 91 Accord has been acting up. Once every few months it just will not start. I then get it towed and then once it gets home it just starts again. This time it has been 4 days it will not start or react to a jump. I think it may be the distributor but I'm not sure. What else could it be? And how hard is it to replace the distributor??
it sounds like it is going to turn over but doesnt have enough ummmfff. Ya know what I mean no clicking. And the started was replaced 2 months ago. I thought thats what it was so i fixed it....but the problem is back again!
A distributor is not bad at all. But see if you can't replace just the cap or something first. Maybe it's got a crack or something and is grounding out. I always say replace the cheap stuff first and then if it still doesn't work . . . rig it! Or buy the expensive part, whatever.
i agree with H22 check your distributor cap first...and the little rotor inside for ware and then replace if necessary...also when was the last time you changed your feul filter?
I've had two honda's where after work they would not start for about 1/2 hour. This usually happened when the weather was hot. I'd get out to the car, open the windows, pop the hood and try to figure out why it wouldn't start. Called the tow truck and when they came it started right up. This problem has only happened on our older hondas. Someone told me that Honda has a part called a starter relay. It is located somewhere under the steering column. On two accords this was the problem. Its a suggestion for something to check.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3rd accord »</TD></TR><TR><TD CLASS="quote"> I've had two honda's where after work they would not start for about 1/2 hour. This usually happened when the weather was hot. I'd get out to the car, open the windows, pop the hood and try to figure out why it wouldn't start. Called the tow truck and when they came it started right up. This problem has only happened on our older hondas. Someone told me that Honda has a part called a starter relay. It is located somewhere under the steering column. On two accords this was the problem. Its a suggestion for something to check. </TD></TR></TABLE>
4th gen accords are notorious for main relays going bad... so thats def something to check out
It COULD be the ditributor, or a part of it anyway. The distribitor on my 91 was trash. And Honda dizzys are not known for their longevity. If it's the original part and not causing your current problem it will act up sometime. I got a good deal on mine at http://www.importperformanceparts.net
Good luck.
Good luck.
