would this work???
Old Dec 9, 2001 | 07:07 PM
1sick4door's Avatar
Default would this work???
i have a 1st gen b16 head..i need an intake manifold...i was told an ls intake manifold would work....doess anyone knows this for sure??reason is i found one for chep..just looking to get my car running..also if i do use an ls intake manifold would the vtec still work?
Old Dec 10, 2001 | 07:31 AM
Spade's Avatar
Default Re: would this work??? (1sick4door)
you might have to make small adjustments to it but it should.
Old Dec 10, 2001 | 09:57 AM
RedlinedVTEC's Avatar
Default Re: would this work??? (Spade)
Yes it WILL fit and yes VTEC will still work.
Old Dec 10, 2001 | 12:07 PM
Katman's Avatar
uhh..its not a direct bolt onto a b16a head.
Modification is needed. You'll have to drill some new holes and do somthing about the coolant spout feed into the head. Or you can just buy a 89-91 b16a intake manifold for dirt cheap off someone...those things aren't rare...
[Modified by Katman, 1:08 PM 12/10/2001]
vartok
Feb 11, 2013 06:33 PM
kasperwhoo
Aug 23, 2011 05:01 AM
spun13
Aug 21, 2007 09:46 PM
nihad
18
Dec 20, 2006 08:39 AM
InfamousRS
May 2, 2002 10:42 AM
