Camber problem with Omni Power coilovers?
Old Sep 16, 2004 | 11:25 AM
genetsang's Avatar
Default Camber problem with Omni Power coilovers?
searched... but was wondering if anybody is having camber issues with their Omni Power coilovers.... or did you ppl pick up the Omni Power camber kit with it....
Old Sep 16, 2004 | 11:28 AM
B2FiNiTY's Avatar
Default Re: Camber problem with Omni Power coilovers? (genetsang)
Depends how low you set it. If it's having camber issues, time to pick up a camber kit.
Old Sep 16, 2004 | 11:30 AM
Chris N's Avatar
Huh?
You don't get a camber problem from coilovers. What does 'camber issues' mean anyways?
1. you buy coilovers and install them.
2. your car may be lower, and if so, you gained more negative camber and more toe in.
3. to fix this, you buy adjustable camber arms (upper A arms) and you adjust the camber, then adjust the toe.
4. Done
I don't fully understand what you are asking, but if you think you can slap on a coilover and all will be well with camber and toe, you're wrong.
Old Sep 16, 2004 | 11:36 AM
genetsang's Avatar
Default Re: Camber problem with Omni Power coilovers? (Chris N)
car is not even sitting that much lower than stock.... the contact patch on the road is in the inner part of the tire. (positive/negative camber.. i forget what its called).
i raised it all the way to the highest point.. contact still sitting on the inner part of the tire.... ill try reinstalling it all over again...
you guys did not pick up the camber kit though?
Old Sep 16, 2004 | 11:39 AM
Chris N's Avatar
Why not lower the car? It's not supposed to be all the way up or all th eway down.
sohcd16
17
Feb 26, 2009 11:28 PM
gatoraccordingly
Jun 10, 2008 06:08 AM
CrX-To-Tha-Max
Mar 4, 2004 07:17 PM
Ghetto Racing
Sep 19, 2001 06:22 AM
Chip398193
Jul 29, 2001 11:38 AM
