Quaife QR steering rack parts are in!!!
Quaife America has confirmed that the rack parts have arrived in stock, ready to ship next week some time. Both 88-91 and 92-95 Civic non-power steering are available. 3.25 turns lock to lock for the EFs and 2.8 turns lock to lock for the EG. Suggested retail is $239. We need a Honda-Tech sponsoring dealer to put together a group buy, or at least offer discount pricing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker »</TD></TR><TR><TD CLASS="quote">I don't know about your car, but my STD (which allegedly has the same steering ratio as the Si's) is almost 4 turns lock to lock (3.88 I think).</TD></TR></TABLE>
Well, even at that...is a 1/2 turn improvement really going to be noticeable?
I've never really thought my car was too bad. Just a PITA sometimes lock-to-lock out of a parked position.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke »</TD></TR><TR><TD CLASS="quote">http://ef-honda.com/main/viewtopic.php?t=5547</TD></TR></TABLE>
great info there. let me post it for the lazy peeps...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">So it's only the rack parts? Not a whole crossmember with the rack parts?</TD></TR></TABLE>
It only includes the rack (bar with the teeth ground into it) and the pinion with the bearing pressed on. It may include a seal for the pinion, but I'm not sure about that. You need to take your rack out, disassemble it, and swap the parts into your existing housing.
Ahhhh ok, I see.
Ahhhh ok, I see.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker »</TD></TR><TR><TD CLASS="quote">Quaife America has confirmed that the rack parts have arrived in stock, ready to ship next week some time. Both 88-91 and 92-95 Civic non-power steering are available. 3.25 turns lock to lock for the EFs and 2.8 turns lock to lock for the EG. Suggested retail is $239. We need a Honda-Tech sponsoring dealer to put together a group buy, or at least offer discount pricing.
So is that US or Canadian? I saw you were from Canada just asking. Also if you have a shot rack will these parts replace the parts that go bad?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart »</TD></TR><TR><TD CLASS="quote">
So is that US or Canadian? I saw you were from Canada just asking. Also if you have a shot rack will these parts replace the parts that go bad?</TD></TR></TABLE>
Price is US dollars. Depends on what is shot in your rack. If the rack bar is rusted and pitted badly from a torn inner tie rod boot that lets water into the rack housing (like I've had happen to me in the past), or the pinion shaft bearing is shot, then yes, these parts along with some cheap OEM bits will do the job. If something else is gone, then no.
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
you will need the all the replaceable parts mentioned in Helms, as well as potentially the inner and outer tire rods.
stan
stan
https://honda-tech.com/zerothread?id=993203
https://honda-tech.com/zerothread?id=1181296
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 »</TD></TR><TR><TD CLASS="quote">There's a few threads on this:
https://honda-tech.com/zerothread?id=993205
https://honda-tech.com/zerothread?id=1071512
https://honda-tech.com/zerothread?id=1058751</TD></TR></TABLE>
10cjennings
56
Nov 17, 2014 08:14 AM
Jaker
34
Dec 20, 2004 07:23 AM
Jaker
54
Sep 18, 2004 11:51 PM
