F/S - LS 5th gears from 1st Gen B series Cable transmission
Old Sep 16, 2004 | 09:54 AM
Gearspeed-Performance's Avatar
Default F/S - LS 5th gears from 1st Gen B series Cable transmission
For all you guys that are tired of revving high on the freeway here is a set of good LS 5th gears $100usd shipped. I will also throw in a stock synchro as well.
Will only fit cable B series
Old Sep 16, 2004 | 10:23 AM
Default Re: F/S - LS 5th gears from 1st Gen B series Cable transmission (GearSpeedEF9)
Lunch bumper
Old Sep 17, 2004 | 08:52 AM
Old Sep 17, 2004 | 09:02 AM
Colin's Avatar
Is it a 90-91 or 92-93 gearset.... the 90-91 and 92-93 cable tranny internals are different....
Old Sep 17, 2004 | 09:14 AM
Default Re: F/S - LS 5th gears from 1st Gen B series Cable transmission (91IntegGS)
yes I know they are different.....90-91
Old Mar 12, 2005 | 12:55 AM
fobile missile's Avatar
hello GSEF9, I know this is an old post. I am in trouble or I wouldn't contact you. I was assembling the main shaft of my 90 Integra LS 5 spd manual/cable "S1" tranny. I scrunched the tiny "synchro spring" for the 5th gear. It's mangled. I went to the Honda/Acura parts people but they want me to buy a $160.00 synchro "set".
OK, I admit I made a knucklehead mistake. Should it be a $160 mistake? So I am contacting you to see if you might have one of these little rings lying around from your transmission activities? I'll pay for shipping?
The item I am seeking is the little circular metal band that fits around the outside of the brass synchro ring. On the main shaft the brass synchro rings and springs are all the same size. Do you have an idea what it is I am seeking? I can be reached at boltwestpalm@aol.com . Thank you.
josephcmiller2
Sep 17, 2012 04:09 PM
EJ8chu
Transmission & Drivetrain
Apr 5, 2009 11:10 PM
bzyq2001
Dec 9, 2008 06:30 AM
bzyq2001
Sep 5, 2008 12:11 AM
S13 slide
Sep 8, 2002 01:01 PM
