EK headunit into EF...Yes I searched and got nothing
Old Sep 15, 2004 | 10:40 PM
^Sammy]!.'s Avatar
From: 9/11/01 WTC Never Forget, United States Of America
Default EK headunit into EF...Yes I searched and got nothing
EK headunit into EF has anyone done it before?
If so please post ASAP
Thanx peepolz
Old Sep 15, 2004 | 11:11 PM
^Sammy]!.'s Avatar
Default Re: EK headunit into EF...Yes I searched and got nothing (MR.RED'89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.RED’89 &raquo;</TD></TR><TR><TD CLASS="quote">EK headunit into EF has anyone done it before?
Thanx peepolz</TD></TR></TABLE>
ttt
Old Sep 16, 2004 | 06:40 AM
^Sammy]!.'s Avatar
Common anybody plz
Old Sep 16, 2004 | 07:16 AM
B16CRXT's Avatar
just get the cd player from an integra and it will plug right in and fit perfect. You dont need any adapter harness or anything. I have it in my car and it looks great.
Old Sep 16, 2004 | 07:34 AM
manson's Avatar
Default Re: EK headunit into EF...Yes I searched and got nothing (B16CRXT)
its just wiring. if the plugs are different you need to switch them. in order to switch them you need a wring diagram so you know what wire goes where when you swap the plugs.
Old Sep 16, 2004 | 08:31 AM
sickofjdm's Avatar
it should just plug in.
Old Sep 18, 2004 | 07:11 PM
^Sammy]!.'s Avatar
K so I got the harness for the radio now I need the wiring diagram
Can anyone help me pleaze
Old Sep 18, 2004 | 08:10 PM
^Sammy]!.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.RED’89 &raquo;</TD></TR><TR><TD CLASS="quote">K so I got the harness for the radio now I need the wiring diagram
Can anyone help me pleaze</TD></TR></TABLE>
Old Sep 18, 2004 | 08:18 PM
B16CRXT's Avatar
give us some details. Why did you buy a harness anyways? if you bought the right one then all you have to do it plug it into the stock harness and into the cd player.
Old Sep 18, 2004 | 08:44 PM
YumVTEC's Avatar
i'm assuming when you say EK you mean 99+. you need a plug to go into the back of the EK unit, you can cut one out of most 99+ hondas, or oder one on the internet. then you need to go to a stereo shop and get the female plug that you can plug your stock radio plug into. then you have to match the wires, solder, tape, and plug in. i have an s2k head unit in my ef.
Old Sep 18, 2004 | 08:47 PM
EF4lyfe's Avatar
your original head unit in your ef should have the wiring diagram printed on the bottom, and so should the one your putting in, this should be a simple task for anyone, im sure you can figure out what to do from there
Old Sep 19, 2004 | 05:22 AM
^Sammy]!.'s Avatar
Default Re: (SIhatch90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIhatch90 &raquo;</TD></TR><TR><TD CLASS="quote">your original head unit in your ef should have the wiring diagram printed on the bottom, and so should the one your putting in, this should be a simple task for anyone, im sure you can figure out what to do from there</TD></TR></TABLE>
Negative I didnt have a stock headunit in my EF i had a Kenwood and it died on me (was old anyways) I matched up all the wires color by color but there are some extra wires on the EK radio harness and on the wires on my EF there are 2 wires that do not match with the EK harness...
Also the 99 EX radio does not have the wiring diagram on it.....
Old Sep 19, 2004 | 05:43 AM
Home Skillet's Avatar
Default Re: (MR.RED'89)
What are the wire colors that you need info for?
Old Sep 19, 2004 | 06:43 AM
^Sammy]!.'s Avatar
Default Re: (Home Skillet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Home Skillet &raquo;</TD></TR><TR><TD CLASS="quote">What are the wire colors that you need info for?</TD></TR></TABLE>
Okay on the EF radio harness the wires are:
White with Blue Stripe
Yellow with Red Stripe
On the EK radio harness the wires are:
Red
Blue
Black (thick)
Green with Red Stripe
White (thick) Red Stripe
White (thick) Green Stripe
Old Sep 19, 2004 | 07:10 AM
^Sammy]!.'s Avatar
Quote, originally posted by Home Skillet »
Red
Blue
Black (thick)
White (thick) Green Stripe</TD></TR></TABLE>
Old Sep 19, 2004 | 08:21 AM
White W/ blue stripe = 12V illumination
Yellow W/ red stripe = 12V Acc
As for the EK wires, did the radio come from a car that had keyless entry installed?
Old Sep 19, 2004 | 05:28 PM
^Sammy]!.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Home Skillet &raquo;</TD></TR><TR><TD CLASS="quote">White W/ blue stripe = 12V illumination
As for the EK wires, did the radio come from a car that had keyless entry installed? </TD></TR></TABLE>
Yes it did
Does that matter?....How?
Old Sep 19, 2004 | 05:42 PM
^Sammy]!.'s Avatar
Damn I still can get this damn radio to work
Old Sep 19, 2004 | 06:12 PM
oneslowrex's Avatar
Okay, what year car did this radio come from? 98 and earlier? Or 99 and later? If it's a 98 then your factory harness will plug right in. If you don't have the factory harness then you'll want to test the wires with a digital multi meter. If it's from a 99 and up there will be two illumination wires where everything before 99 only had 1 wire. That just means the radio won't dim with your dimmer switch. If you've got everything hooked up and it still won't turn on, you need to check both (2) fuses. One is under the dash as normal, the other is under the hood and is labeled backup. It is a 7.5 volt fuse. Hope this helps.
Old Sep 19, 2004 | 06:33 PM
^Sammy]!.'s Avatar
Default Re: (oneslowrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneslowrex &raquo;</TD></TR><TR><TD CLASS="quote">Okay, what year car did this radio come from? 98 and earlier? Or 99 and later? If it's a 98 then your factory harness will plug right in. If you don't have the factory harness then you'll want to test the wires with a digital multi meter. If it's from a 99 and up there will be two illumination wires where everything before 99 only had 1 wire. That just means the radio won't dim with your dimmer switch. If you've got everything hooked up and it still won't turn on, you need to check both (2) fuses. One is under the dash as normal, the other is under the hood and is labeled backup. It is a 7.5 volt fuse. Hope this helps.</TD></TR></TABLE>
The radio came out of a 2000 Civic EX
I checked the fuse under the dash and it was blown
but didnt check the other one
Old Oct 4, 2004 | 07:35 PM
^Sammy]!.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.RED’89 &raquo;</TD></TR><TR><TD CLASS="quote">Damn I still can get this damn radio to work</TD></TR></TABLE>
Old Oct 5, 2004 | 02:56 AM
I sent you an email because We-Todd doesn't support PDF's. It's a wiring diagram for Honda radio harnesses with wire colors and all. If I can convert it to a jpeg then I'll post it up for all to see but for now, you got mail.
Old Oct 5, 2004 | 06:46 AM
^Sammy]!.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Home Skillet &raquo;</TD></TR><TR><TD CLASS="quote">I sent you an email because We-Todd doesn't support PDF's. It's a wiring diagram for Honda radio harnesses with wire colors and all. If I can convert it to a jpeg then I'll post it up for all to see but for now, you got mail. </TD></TR></TABLE>
Thanx Skillet
Old Oct 5, 2004 | 05:35 PM
B16CRXT's Avatar
I wish you'd have gotten the DC2 cd player. it IS plug and play to the factory raido harness. woulda had it playin in less than five minutes.
Rhonda14
Suspension & Brakes
Apr 5, 2011 11:11 AM
efcrew
Jul 18, 2007 04:25 PM
hellogoodbye
Jan 17, 2006 03:06 PM
sircrxracer
15
May 17, 2005 07:56 AM
eg360B
May 25, 2004 11:52 AM
