I need your help going to the dyno tomorrow
Old Sep 15, 2004 | 09:06 PM
FastKTJ's Avatar
Default I need your help should I go to the dyno tomorrow or not?
I made a appointment to dyno my new setup in the morning. Before spending the money I want to make sure the time is right. I have a 95 integra Gsr the motor has oversized jdm itr pistons, P&P head with crane stage 2 cams, skunk 2 valvetrain, P&P skunk 2 manifold, dc short ram intake, Magnecor's KV85 Competition (8.5mm) wires, comptech 4-2-1 header and catback, b&m fpr with gauge, Vafc and a 2 layer headgasket. The problem is I'm still running the stock p-72 with the 8200 redline will that be a problem on the dyno? The motor also is brand new with about 100 miles on it now will that be a problem? I've heard the comp keeps changing for like 2500 miles so will the numbers be low when I dyno it?
Thanks for the help once again,
Kevin
Modified by FastKTJ at 6:19 AM 9/16/2004
Old Sep 15, 2004 | 09:20 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: I need your help should I go to the dyno tomorrow or not? (FastKTJ)
If the motor only has 100 miles on it, break it in first. You got a VAFC and some cam gears?
Old Sep 15, 2004 | 10:07 PM
92RED Hatch's Avatar
Default Re: I need your help should I go to the dyno tomorrow or not? (LSVTEC 91 Civic)
dude you need to break that motor in before you go and dyno it....if you don't you'll wish you did later......do a search on what happens to most motors that don't get broke in properly......1.they don't last 2. they put down shitty numbers 3. You'll waste a lot of money just b/c of number 1.
Yeah and with those mods you need a source of engine management...seriously..hope you do the right thing for your sake...good luck
MTVtec
Apr 30, 2009 06:38 AM
CIVICctr
19
Nov 15, 2006 09:17 PM
Tbone
36
Nov 9, 2005 08:09 PM
kentuckyprelude
Oct 31, 2004 09:27 PM
maggsgsr
Nov 5, 2002 12:42 PM
