Question about JUN 2 cams
Old Dec 9, 2001 | 05:46 PM
scooter's Avatar
Default Question about JUN 2 cams
I saw the post from Mike K. with the dyno of the intake cam only and it looked like the cam fell off a little on the top. The question is if you were to use the JUN 2 exhaust cam with the intake would the power up top climb or level off instead of dropping?
thanks
scott
Old Dec 9, 2001 | 06:47 PM
gsr98vtec's Avatar
Default Re: Question about JUN 2 cams (scooter)
well if you look at the spec of the jun 2 vs itr exhaust cam you see a slight difference...the specs are as follows
jun 2 exhaust cam
lift = 10.9mm
duration = 265
itr exhaust cam
lift = 10.5mm
duration = 235
now the thing is .4 on the jun2 is not that much i would think to make a difference but what about duration...would that full 30 make a huge difference up top...i myself dont know, but if i only gain 2-3whp by using a 450.00 cam i would be pissed...i would rather stick with the jun2/itr combo than waste the money for the exhaust cam...can anyone answer what effect duration has on the cams and engine
[Modified by gsr98vtec, 3:48 AM 12/10/2001]
Old Dec 9, 2001 | 06:49 PM
Hybrid ctr's Avatar
Default Re: Question about JUN 2 cams (gsr98vtec)
duration = top end power
Old Dec 9, 2001 | 06:52 PM
gsr98vtec's Avatar
Default Re: Question about JUN 2 cams (Hybrid ctr)
but how much duration is really needed to see that power...is 30 alot...now looking at it, it seems like that would add some power up top, but the real question is how much
Old Dec 9, 2001 | 06:54 PM
Hybrid ctr's Avatar
not enough for a $450 price tag
Old Dec 9, 2001 | 06:56 PM
gsr98vtec's Avatar
thats what i thought...thanks for the lesson on cams man
Old Dec 9, 2001 | 06:58 PM
scooter's Avatar
Do the JUN 2 and 3 exhaust cams have different specs? I thought I read somewhere that they are the same. Just curious.
scott
Old Dec 9, 2001 | 06:59 PM
kenji's Avatar
25 Year Member
I understand that the Jun2 exhaust cam is not cheap. But, has anybody actually tried both the Jun2 intake AND exhaust cam together (on a well built high compression setup)?
I would imagine the top end would pick up as compared to the Jun2 intake cam and ITR exhaust cam combo. Afterall, these cams were designed to work as a pair.
Just something to think about...
-kenji
Old Dec 9, 2001 | 07:31 PM
gsr98vtec's Avatar
Default Re: Question about JUN 2 cams (kenji)
true and to answer a previous question the jun 3 exhaust cam has a bigger lobe and all...check out the specs on junauto.co.jp
all the cams specs are on there or go to http://www.allmotorhonda.com they have specs also
Old Dec 9, 2001 | 08:06 PM
naturalvx's Avatar
I think some people are using the Intake/Exhaust combo. I have a Jun2 Exhaust cam in stock if anyone wants to test it. I know one person is working on it, but if anyone with just hte intake wants an exhaust I have one.
Old Dec 9, 2001 | 08:18 PM
gsr98vtec's Avatar
Default Re: Question about JUN 2 cams (naturalvx)
i just got my jun 2 in from japan on friday...only 500 express shipped to the US, but anyway how much for the exhaust cam, i might want to try it
Old Dec 9, 2001 | 08:51 PM
naturalvx's Avatar
467 free shipping.
Old Dec 9, 2001 | 09:46 PM
gsr98vtec's Avatar
this is wes at titan correct
Old Dec 10, 2001 | 06:27 AM
naturalvx's Avatar
the one and only.
vtecmasta85
29
Sep 16, 2013 02:16 PM
Ronin Panda
Jan 8, 2004 06:23 AM
hondaboyB18C1
Dec 16, 2003 01:59 PM
itr501
Dec 10, 2001 06:10 PM
gsr98vtec
Dec 8, 2001 11:28 AM
