should i get some thing like this?
Old Sep 15, 2004 | 07:04 PM
99RedTeg's Avatar
Default should i get some thing like this?
i alsy have used a mig welder but never tig, and i know tig cost a arm and leg. do you guys think this is worth getting? or has any oen use this kind of tig welder before?
http://cgi.ebay.com/ws/eBayISA...&rd=1
or
Old Sep 15, 2004 | 07:16 PM
mugensport9's Avatar
Default Re: should i get some thing like this? (99RedTeg)
i would also like to know
Old Sep 17, 2004 | 10:46 PM
99RedTeg's Avatar
Default Re: should i get some thing like this? (mugensport9)
bump
Old Sep 24, 2004 | 08:37 PM
robb$ta's Avatar
tig welders are acually easy to use just make sure your using it just for alumium plus it actually easer than mig
Old Sep 24, 2004 | 09:44 PM
CagedRuss's Avatar
What do you plan on welding. 90 amps isn't much good for anything over exhaust tubimg. Where do you find service for that machine or replacement parts? Be careful in what you buy. You generally get what you pay for.
Old Sep 25, 2004 | 05:50 AM
david@didrace.com's Avatar
Default Re: should i get some thing like this? (CagedRuss)
Yup, best bet would be to get a used Tig machine of better quality, something with A/C would help if you want to weld aluminum easily.
A simple guide for what a welding machine could handle is to take the maximum amperage output and move the decimal three places to the left.
So maximum output of 100 amps means that a welder can at maximum, get full penetration on 1/10" or (.100") metal. Of course you can always bevel down to the root on the material and lay multiple passes, but this is just a guide to find out what can be done in a single pass.
Old Sep 25, 2004 | 12:16 PM
Canuk_SiR's Avatar
Default Re: should i get some thing like this? (D.I.D. Race)
for under $400, that's not a bad price for a DC only machine. But all you'd be able to do is steel, no aluminum with that machine, and it would be thin steel only, so if you're doing exhausts and such then that would be fine.
I"d consider getting something with AC as well though, and something that can handle higher amperages. 90 amps is very limiting.
turbojeesx
Welding / Fabrication
10
May 5, 2012 04:32 AM
stiffdogg06
Jan 27, 2009 05:17 PM
ToxicFabrication
39
Jan 8, 2009 01:57 PM
DESTROYER
19
Aug 13, 2008 11:45 PM
Ajax
Mar 25, 2005 10:15 AM
