Neuspeeds sit high in the rear anyone?
I have soft sports and it looks as if my car is about 1/2" higher in the rear. Anyone else have neuspeeds with this prob? My car is a auto coupe with a/c(lotta wieght up front?) and nothing in my trunk.
Most springs sit high in the rear. If you want something better you should've gone with an adjustable spring/sleeve like Ground Control.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Most springs sit high in the rear. If you want something better you should've gone with an adjustable spring/sleeve like Ground Control.</TD></TR></TABLE>
I had skunk 2's I wanted something smooth riding that was high enough to not have that mest up camber. I guess its normal then to sit a lil higher.
i have Neuspeed sports and my rear is a little higher than the front. obviously cuz its a 1.75 drop in the front and a 1.5 drop in the back.....
88LXi68
Suspension & Brakes
18
Aug 8, 2018 11:13 AM
Fightin'Irish
Mar 13, 2002 12:21 PM
