noob here need a lil help picking parts
just like to say im a noob and i got a 90 crx hf and i have a b16a swap.what i i have done so far is
dc header 4-1 2in
dc catback 2in
typhoon intake
aem short ram
aem fuel rail
fuel regulator and gauge
cam gears
8.mm wires
light crank pulley
short shifter
hasport motor mounts
hasports shift link
zex 55 shot
nitto r555 drag
ok now what i need to know is,is this setup bad?what parts do i need next to help my times for the buck and what brands.
im leaning to get these next, so do i need to go this way?
light flywheel
valves
springs
retianers
throttle body (to go with this setup)
cams
lsd
So what brands or what way do i need to go about doing this?
Right now the way my car is i run a 11.37 with a 55 shot in the 1000ft but i got a bodykit, widebody,hood but im about to take it all off and make it a drag car.
dc header 4-1 2in
dc catback 2in
typhoon intake
aem short ram
aem fuel rail
cam gears
8.mm wires
light crank pulley
short shifter
hasports shift link
zex 55 shot
nitto r555 drag
light flywheel
valves
springs
retianers
cams
lsd
did you buy the car with it already modded? are you sure it is running low 11's or is that what the previous owner told you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidrolla »</TD></TR><TR><TD CLASS="quote">just like to say im a noob and i got a 90 crx hf and i have a b16a swap.what i i have done so far is
dc header 4-1 2in
dc catback 2in
typhoon intake
aem short ram
aem fuel rail
cam gears
8.mm wires
light crank pulley
short shifter
hasports shift link
zex 55 shot
nitto r555 drag
light flywheel
valves
springs
retianers
cams
lsd
Right now the way my car is i run a 11.37 with a 55 shot in the 1000ft but i got a bodykit, widebody,hood but im about to take it all off and make it a drag car. </TD></TR></TABLE>
dc header 4-1 2in
dc catback 2in
typhoon intake
aem short ram
aem fuel rail
cam gears
8.mm wires
light crank pulley
short shifter
hasports shift link
zex 55 shot
nitto r555 drag
light flywheel
valves
springs
retianers
cams
lsd
i got slips but i think it should be faster then it is and the car has been built from ground up.so what do you think i should do and what times should i be runing?
o yeah thats 1000ft times theres not a 1/4 track anywhere near me
qajobipolar
13
Sep 4, 2009 02:34 AM
EKway2low
16
Mar 19, 2008 07:17 PM
