Where to find / Need Help.. Front Sway Bar Bushings..
Old Sep 15, 2004 | 05:57 PM
QUiKSR20's Avatar
Default Where to find / Need Help.. Front Sway Bar Bushings..
I need to redo my front sway bar bushings. There smashed the bolts/nuts
are all rusty etc. Where Can I find a rebuild kit. Or an ES or Equivilent..
Ive seen some at various sites. But they list all diff sizes and part #s for CRX's and im not sure which to get. I have an 89 CRX Si. Any help would be
greatly apreciated. I have searched and havent found any solid data.
Thanks in Advance,
Old Sep 15, 2004 | 05:59 PM
crxgator's Avatar
Default Re: Where to find / Need Help.. Front Sway Bar Bushings.. (QUiKSR20)
suspension.com
Old Sep 15, 2004 | 06:09 PM
XrcR6's Avatar
^ Ditto, good place.
Last time I was on their site, the ES listings show 17, 18 and 19mm.
OEM front thickness is 18mm, well it is on my 91 CRX-Si. Every Si I've seen (various) support this with one exception, someone I trust has told me theirs was actually different, and a caliper confirmed it. If you have a caliper you could double check yourself. Also, Honda typically casts the swaybar thickness into the side of the swaybar bushing (the D shaped one, not the endlinks).
17mm should be for the HF, 19mm is for the Wagon.
So, assuming you are stock, I'd think you need:
"Front Sway Bar Frame Bushings (pair)" 16-5110
and
"Front End Links (pair)" 16-8104
Old Sep 15, 2004 | 06:18 PM
QUiKSR20's Avatar
Default Re: Where to find / Need Help.. Front Sway Bar Bushings.. (XrcR6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XrcR6 &raquo;</TD></TR><TR><TD CLASS="quote">^ Ditto, good place.
and
"Front End Links (pair)" 16-8104</TD></TR></TABLE>
Awesome yeah this is a stock 89 Si with stock sway bar. Im just looking to
replace the bushings in the sway bar for now.
Old Sep 16, 2004 | 11:24 PM
CRX_1.8T's Avatar
i replaced all of my bushings with the bushing set by "Energy Suspension." it is pretty extensive and covers pretty much everything, even the trailing arm.
Old Sep 16, 2004 | 11:40 PM
Tyson's Avatar
H&R offers the best sway bar bushings.
Old Sep 17, 2004 | 05:53 AM
QUiKSR20's Avatar
Default Re: Where to find / Need Help.. Front Sway Bar Bushings.. (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">H&R offers the best sway bar bushings.
Nice.. What about the round ones that go in the end links I need those too.. I need all the bushings for the front sway bar.
Old Sep 17, 2004 | 08:15 AM
Tyson's Avatar
blah, tyson dont read well. sorry. the front bushings are available thru ES or OEM, those arent a big deal.
Old Sep 17, 2004 | 08:20 AM
jc836's Avatar
You can use the Energy Suspension ones Like I did. Check their online catalog. The parts are available from both Summit and Ultra Performance.
amej8
Apr 18, 2007 02:25 PM
1993 Civic Si
Sep 24, 2006 06:52 PM
JCracer723
11
Mar 26, 2004 09:20 AM
g_man80
Apr 22, 2003 11:49 AM
