valve spring compressor with head off car?
Old Sep 15, 2004 | 05:51 PM
743power's Avatar
Default valve spring compressor with head off car?
Has anybody had any luck using a snap-on or schley "on the car" style ohv valve spring compressor, with the head off the car? If so, what do you use to keep the valves from going down?
I'd rather not buy another valve spring compressor if it is not needed.
Old Sep 15, 2004 | 06:00 PM
chad's Avatar
Moderator
Default Re: valve spring compressor with head off car? (743power)
post pic of the valve spring compressor you are using....
valves usually don't fall because of the valve guide seals!!!
Old Sep 15, 2004 | 06:35 PM
743power's Avatar
Default Re: valve spring compressor with head off car? (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">post pic of the valve spring compressor you are using....
valves usually don't fall because of the valve guide seals!!!</TD></TR></TABLE>
http://buy1.snapon.com/catalog...talog
yea, I know the valves stay up, but it is kind of a pain if I accidentally knock into it with the retainer and it slides down a little. I think I will go and see how far I get.
Old Sep 15, 2004 | 07:25 PM
Big Teggie's Avatar
You can pressurize the cyl and that should hold the valves up.
Old Sep 15, 2004 | 08:01 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: valve spring compressor with head off car? (Big Teggie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Teggie &raquo;</TD></TR><TR><TD CLASS="quote">You can pressurize the cyl and that should hold the valves up.</TD></TR></TABLE>
Old Sep 16, 2004 | 04:04 AM
rice4life's Avatar
this wont work with the head off the engine. just stuff a piece of towe under the valve so it doesn't fall back down.
Old Sep 16, 2004 | 04:29 AM
Big Teggie's Avatar
Default Re: valve spring compressor with head off car? (rice4life)
I thought he said on the car, my mistake.
Anyways, just put a rag in the chamber in and clamp the head down to a table. Works for me
HumanResource
Jan 8, 2009 07:31 AM
93SIRII
May 2, 2005 08:43 PM
2fknlo
May 6, 2003 06:49 AM
