CRX ice box
i was just wondering if anyone has or has ever seen an ice box on a rex. im thinking about attempting a home made one and just wondered if anyone else has done this. if you have let me know how you did it, what materials u used and post a pic. Thanks
are you serious?
its kinda like a cold air intake but only there is better air flow and you don't have to worry about hyro-lock (in ohio)
so the integra air box will fit in the crx location? I'm guessing you use the integra air box instead of the rex air box because it is bigger? correct me if im wrong
i hope you don't have a cold air intake and have never heard of hydro lock before. it basically were water is sucked up into the engine= bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigDawwg6969 »</TD></TR><TR><TD CLASS="quote">what is hydro-lock? Never heard this term before. Anyone have any pics of these "ice boxes"?</TD></TR></TABLE>
Sucking in water.
https://honda-tech.com/zerothread?id=834028
http://www.geocities.com/bretq....html
And for the lazy
Sucking in water.
And for the lazy
is that a ice box or just a air box? what years of integra will fit? is there a difference between GSR, LS and GS? what do you have to mod to get it to fit?
That is the OEM integra GSR box.
I am not positive but I assume all integra boxs are the same and the only difference is the pipe the goes behind the bumper is different on the type R.
I have not done this on my CRX yet and I dont know if I will since I am going with ITB's now.
I was going to use a aftermarket intake pipe that has only one bend by the throttle body(any cheap pipe would work).
K&N filter
and the GSR box
from looking at it it looks real easy to make work it just depends on how fancy you want it to look in the end.
I know it will work you will just have to make a bracket or tap some hole to mount the box down.
K&N filter
and the GSR box
If you have a 90/91 crx I would use the "fog light" holes, I have my passenger side one cut out.
The box isnt that much bigger then the crx box so it should fit well but since I have not done this myself yet I can not varify anything.
i would have sworn an ice box was a box jull of ice you put around your fuel line to keep it cool.
how do you prevent water from getting sucked up with the cold air intakes? i was gonna make a hood scoop for my civic but did know how to keep the water out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coot_er »</TD></TR><TR><TD CLASS="quote">do you mean to take out the light that is there or to cut a new hole right below? </TD></TR></TABLE>
Below the blinkers on the 90/91 crx they have fog light holes but any bumper could be modded to drag air up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by draw »</TD></TR><TR><TD CLASS="quote">i would have sworn an ice box was a box jull of ice you put around your fuel line to keep it cool.
how do you prevent water from getting sucked up with the cold air intakes? i was gonna make a hood scoop for my civic but did know how to keep the water out </TD></TR></TABLE>
Avoid water or use a bypass valve.
anyhow back to my post
no one has put an ice box on a rex?
i think i might try to be the first. i think im growing out of the noob stage so maybe it will be good for me to write up a diy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coot_er »</TD></TR><TR><TD CLASS="quote">i have read that the bypass valve dont do ****. the best way is not to use it</TD></TR></TABLE>
exactly.
Short rams work best since they are less restrictive so if you can bring air to them you will make more power and not have to worry about water.
exactly.Short rams work best since they are less restrictive so if you can bring air to them you will make more power and not have to worry about water.
Here is somebody with a crx but the pics are down, PM him and maybe he will repost.
https://honda-tech.com/zerothread?id=595541
