5 lugs ITR kit on EF
Old Sep 15, 2004 | 03:20 PM
Garrett's Avatar
Default 5 lugs ITR kit on EF
After talking with BLackR, how is the only guy I know that made the ITR 5 lugs on EF
https://honda-tech.com/zerothread?id=683522
Before the 5 lugs swap I was septic about the camber and the wheel position on the fender.
See what is give on my car
The wheel is not perfectly centered in the fender and I had a lot of positive camber
Know I think that I should changed my knuckle for a DA one and install the 5 lugs HUb on the DA knuckle
Modified by Garrett at 1:59 AM 9/16/2004
Old Sep 15, 2004 | 04:01 PM
bossman032's Avatar
Default Re: 5 lugs ITR kit on EF (Garrett)
umm get an alignment done
see how much they are off and also try a camber kit
nice looking setup
Old Sep 15, 2004 | 04:11 PM
crxgator's Avatar
Default Re: 5 lugs ITR kit on EF (bossman032)
you cant adjust the caster on 88-91 crx/civics, so no point in really getting an alignment...
and your right, you should have used DA/EX knuckles and swapped out the hub...
Old Sep 15, 2004 | 04:15 PM
Garrett's Avatar
Default Re: 5 lugs ITR kit on EF (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">you cant adjust the caster on 88-91 crx/civics, so no point in really getting an alignment...
and your right, you should have used DA/EX knuckles and swapped out the hub... </TD></TR></TABLE>
BUt do you know if the 5 lugs hub fit on the DA knuckle?
Old Sep 15, 2004 | 04:26 PM
crxgator's Avatar
http://battlecat.8m.com/ITR%20...A.htm
https://honda-tech.com/zerothread?id=207764
Old Sep 15, 2004 | 04:37 PM
Garrett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">http://battlecat.8m.com/ITR%20...A.htm
https://honda-tech.com/zerothread?id=207764</TD></TR></TABLE>
Thanks to you so much
Old Sep 15, 2004 | 04:49 PM
LAMA's Avatar
what are the rims on the back?
i like both sets
Old Sep 15, 2004 | 04:55 PM
Garrett's Avatar
Default Re: 5 lugs ITR kit on EF (LAMA)
I don't know the brand 15", 17 pounds, the are on the rear on my Red EF because the rear 5 lugs wasn't installed
Were white
Now flat black
Old Sep 15, 2004 | 05:07 PM
LAMA's Avatar
tahnks, they look really good in black.
but so do the itr's.
Charlie Moua
Oct 5, 2010 07:17 PM
Mr.Milton
Jun 20, 2007 01:07 PM
JapJunkie
20
Jan 14, 2006 10:57 AM
