Can someone tell me about my joints?
hey everyone... can someone point out some parts for me? I just got myself a pitman puller and need to know how to use it. I was just wondering in the first picture, is that where you put the arm or claw on and push it up? And on the second picture, tell me if I'm wrong but #1 is lower ball joint, #2 is the tie rod, and whats #3??? Thanks for the help.
#1 lower ball joint. #2 ball joint off the rack and pinion stering (tie rod). #3 looks like the sway bar end. yes in pic one, that is where you would place the fork, just lossen the crown nut and give it a bunch of nice bangs with the fork/claw/puller deal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fe519 »</TD></TR><TR><TD CLASS="quote">hey everyone... can someone point out some parts for me? I just got myself a pitman puller and need to know how to use it. I was just wondering in the first picture, is that where you put the arm or claw on and push it up?</TD></TR></TABLE>
oh **** did not see that... do not use that tool noOb 'cause u well f#ck up the ball joint boot... use a ball joint separator... hold on i well get a pix for ya
this was discussed a few months ago, and with some practice and patience as to not **** anything up, you can use a 10 pound sledgehammer by hitting the lower control arm and NOT THE BALLJOINT!!! leave the nut on so just in case you miss, you don't get owned by f'd up threads.....
but the balljoint puller is the safest way
I'm just a poor mechanic with a prelude addiction that won't die
PandaBear
Suspension & Brakes
Jul 22, 2006 08:26 AM
MiX
Dec 27, 2004 07:32 PM
