***Clean Engine Bay***
Old Sep 15, 2004 | 01:00 PM
608 Gangsta's Avatar
Default ***Clean Engine Bay***
I got all my ac and power steering out there anything else i can take out it would be nice to see just the motor lol i know thats not possible but there anything else i can remove and still function..?? thnx
Old Sep 15, 2004 | 01:12 PM
Jurassic Four's Avatar
From: Where you cant steal it, Maryland, United States
Default Re: ***Clean Engine Bay*** (LsFrnknstn)
By "searching" I found this:
Old Sep 15, 2004 | 01:16 PM
SETI20's Avatar
charcoal canister can go...and just about anything can be moved or relocated.
Old Sep 15, 2004 | 01:46 PM
kid-honda's Avatar
Default Re: ***Clean Engine Bay*** (Jurassic Four)
Thats me WOOT WOOT
How do you remove PS when you dont have it?
Old Sep 15, 2004 | 01:47 PM
kid-honda's Avatar
BTW the only things on any wall in the bay are the brake booster and wiper motor.
Old Sep 15, 2004 | 01:54 PM
John McClane's Avatar
fantastic work.
Old Sep 15, 2004 | 02:03 PM
EVOLUTIONINNYC's Avatar
Default Re: (RockTheMullet)
relocate the battery to the trunk. take out your wiper fluid container. (whatever its called)
Old Sep 15, 2004 | 02:05 PM
LAMA's Avatar
Default Re: (SiRhatchalot)
honda-kid. I saw your cars and they are the hottness.
i wish you would do some kind of how to on the engine bay for your 'baby'
Old Sep 15, 2004 | 02:12 PM
kid-honda's Avatar
Alright here is what I have done and you can see more pics in my link below.
I used a 99 Si TB with a built in map to get rid of the map on the firewall
Got rid of the FITV and lines
Got rid of charcoal canister and lines
got rid of useless "JDM" manifold dashpots and lines
Got rid of vaccume hardlines on manifold(BTW I now only have one vaccume line and its for the FPR)
rerouted clutch cable behind motor
moved fuse box inside of car behind dash
tucked and re routed wires and headlight relays
moved overflow can next to radiator
painted back of headlights black
moved battery to the hatch
If I forgot anything just ask.
Yes it runs and yes it runs perfect with no codes.
This winter I am stripping the car to a bear unibody and doing a full color change and welding all seams and unused hole for a super stiff and clean look.
I am going to replace the prop valve with a shorty from kens and completely remove the booster and I think since I never drive it I will remove wiper motor and arms and make a new plate below the window.
Old Sep 15, 2004 | 02:15 PM
kid-honda's Avatar
Default Re: (LAMA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAMA &raquo;</TD></TR><TR><TD CLASS="quote">honda-kid. I saw your cars and they are the hottness.
i wish you would do some kind of how to on the engine bay for your 'baby'</TD></TR></TABLE>
Thanks
I wished I would have made a writeup since alot of people ask about doing this stuff but if anybody has any questions I will answer the best I can.
Old Sep 15, 2004 | 02:51 PM
blueballs90si's Avatar
wow
Old Sep 15, 2004 | 08:26 PM
dxasylum's Avatar
Default Re: ***Clean Engine Bay*** (kid-honda)
clean. I like it.
Old Sep 15, 2004 | 10:05 PM
rjay8604's Avatar
Default Re: ***Clean Engine Bay*** (dxasylum)
no brake booster eeek. those are good for "stopping".
Old Sep 15, 2004 | 10:10 PM
Default Re: (kid-honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">BTW the only things on any wall in the bay are the brake booster and wiper motor.</TD></TR></TABLE>
he only has a brake booster an wiper motor
Old Sep 16, 2004 | 06:52 AM
LiL JoN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jurassic Four &raquo;</TD></TR><TR><TD CLASS="quote">By "searching" I found this:
clean engine bay
Old Sep 16, 2004 | 07:40 AM
eumoria's Avatar
Default Re: ***Clean Engine Bay*** (SingleCam-Vtec)
you should mount the engine in the rear then THAT would be clean!
Old Apr 5, 2005 | 08:04 AM
TallAssFilipino's Avatar
Default Re: ***Clean Engine Bay*** (eumoria)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eumoria &raquo;</TD></TR><TR><TD CLASS="quote">you should mount the engine in the rear then THAT would be clean!</TD></TR></TABLE>
LMAO
Old Apr 5, 2005 | 08:25 AM
SwissChEz82's Avatar
How did you use the 99 Si map? Wouldn't there be a problem with the OBD-2 Map on an OBD-0 car or did you rewire for OBD-2? I would love to get rid of my firewall mounted map.
boostedEBP
Paint and Body
Nov 9, 2007 10:36 PM
Shakes
Mar 4, 2004 06:19 PM
sqwerz
Mar 3, 2004 05:09 PM
" BRANDON HiCKS "
54
Oct 14, 2003 11:39 PM
dingusjt
Aug 7, 2003 01:10 PM
