what clutch are you using?
just wated to know what clutches are most of you using and if it works well?
what set up are you using, tranny motor etc...
planning to get a clutch kit this friday but am unsure of the direction im going towards. i have a y1 tranny on a gsr in my crx and am planning on changing the clutch and pressure plate.
i have an Action 1MS 6 puk sprung on my JDM S1 w/ B17
I have over 25,000 miles on it, 10-15 drag pulls, many dyno pulls, and every day kick your *** in the seat red light pulls.
I checked the condtion 3000 miles ago when i was doing my motor swap to the b17 and it showed some wear, but no nearly as bad as any of my friends clutches after half those miles... Exedy, Clutch Masters, Center Force...
I picked mine up for $350 on a sponsors website if my mind recalls correctly.
EDIT* i will continue to purchase these clutches for as long as i can. Best clutch i have ever used.... Ohh did i mention the fact that its nearly stock feeling. the 2MS is alittle more resistance, but the 1MS is nearly stock. i <3 IT!!!
I have an Exedy organic on my B18C1 w/ YS1 GSR tranny.
Havent really gotten to abuse it yet and put it to the test, but I love how it feels so far. Can't really beat the price either. $175 shipped
JDM YS1 w/LSD ACT 6 puck solid, ACT pp and ACT prolite flywheel so far so good on this setup in my B18C1 CRX. The again I have only 105 miles on the motor since swapped in.
I have a clutch specialties clutch and burn right through it getting ready to install spec stage III clutch kit and flywheel. Put one in my boys h22 civic hatch and a 95 nsx and it works great the best by far.
I have an OEM replacement from the local shop I put in when my clutch came apart at Buttonwillow..
no use for anything else since I am not running anything radical to need a super clutch
The Race car has an Exedy off the shelf clutch and pp
how do spring loaded clutches compare to clutches without the springs. are the clutches with no springs good for the life of your tranny or do they kill the gears?
unsprung clutchs are harsh on a transmission, and harder to shift smoothly on the street at lower rpms-- short version
shorter version
sprung street
unsprung drag/race
shorter version
sprung street
unsprung drag/race
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi »</TD></TR><TR><TD CLASS="quote">I have the act hd PP, and organic full disc on my b18c engine. Its very nice!!
Ryan</TD></TR></TABLE> Same clutch with streetlite flywheel. B16/ JDM S1 tranny. I like it.
I have an RPS turboclutch in my B18C5 and a dual friction centerforce on the B16, both work great.
My last engine/tranny setup on a zc had a clutchmasters stage III street clutch, very highly reccommended!
