any one have 9005 conversion?
Old Sep 15, 2004 | 11:22 AM
GreenMachineRex's Avatar
Default any one have 9005 conversion?
how is it? does it melt ****? do u get high beamed alot?
Old Sep 15, 2004 | 11:29 AM
APC4Life's Avatar
Default Re: any one have 9005 conversion? (GreenMachineRex)
It's great... I got beamed once but i've been rocking it for 8 Mons. It looks really nice and it has not melted anything. It's definately worth it!
Old Sep 15, 2004 | 11:30 AM
eumoria's Avatar
1: No It Doesn't Melt Anything
2: You may get high beamed, but more than likely no because there's a lens difference between the standard lights and the high beams... that's why when you put your brights on the shoot twice as high. The 9005 are brighter, but it shouldn't be irritating to oncoming traffic. (Look at the lexus SUV for christs sake, i don't think it'll even be close to that)
3: I don't have it but a friend does, and if you get the super white 9005 conversion you can see anything!
Old Sep 15, 2004 | 11:31 AM
EVOLUTIONINNYC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APC4Life &raquo;</TD></TR><TR><TD CLASS="quote">It's great... I got beamed once but i've been rocking it for 8 Mons. It looks really nice and it has not melted anything. It's definately worth it!
defintely nice man! i love it, much better. really easy also. i get people flashing their brights at me all the time, but thats cause i adjusted them really far up to see better.
Old Sep 15, 2004 | 11:35 AM
Default Re: (SiRhatchalot)
i once had some fake hid/blue high beam bulbs and they kept buring out.
what type of bulbs did you guys use?
stock looking? or the silverstar/fake hid/bluish/white type bulbs ?
Old Sep 15, 2004 | 11:39 AM
APC4Life's Avatar
Default Re: (GreenMachineRex)
I tried KO:BA, OPTX, and other Blue/White bulbs Best was: Optx By Street Glow (8 Mons!)
Stock Is good & Cheap Though
Old Sep 15, 2004 | 11:41 AM
kid-honda's Avatar
I got it and I love it, nobody flashes me.
Old Sep 15, 2004 | 11:44 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenMachineRex &raquo;</TD></TR><TR><TD CLASS="quote">what type of bulbs did you guys use? </TD></TR></TABLE>
my bulbs came from the junkyard...from 2 different cars. they are only slightly brighter than the low beams. i dont see were there would be a blinding problem.
the low beam wiring looks visually to be the same gauge as the high beam wiring...but im not sure if it really is.
Old Sep 15, 2004 | 12:22 PM
Tyson's Avatar
its not that much brighter that youd be high beamed back at all, it doesnt even change the direction of the light so theres no reason to believe anything is different from an outside perspective. but then, its not that much of a difference anyway to make a worried decision over. i got the extra bulbs from a junkyard, standard bulbs, there is a noticable improvement, but nothing shocking and the color is not changed or anything.
theres no way its going to melt anything anyway. the same type of wires that go to the normal high beam bulb are used for the low beams, so wire gauge isnt an issue for stock. im sure you could benefit from a better wire harness tho.
if your lowbeam bulb is out, just replace it with a normal 9005 i say. you dont have to do the silverstar or xenon green rice bulbs to do the conversion anyway. its such a simple modification everyone should do this.
Modified by Tyson at 6:43 PM 9/16/2004
Old Sep 15, 2004 | 01:04 PM
John McClane's Avatar
Default Re: any one have 9005 conversion? (Tyson)
i think im going to try it.
Old Sep 15, 2004 | 01:12 PM
vicious666's Avatar
do it. im pretty happy with mine. i have silverstars on mine, high and low.
Old Sep 15, 2004 | 01:27 PM
Outsane's Avatar
Default Re: (vicious666)
scad bit brighter, and I have never been high beemed..
Old Sep 16, 2004 | 01:44 PM
Default Re: (Outsane)
QUICK! what bulbs should i buy to do this? im going to buy them now!
Old Sep 16, 2004 | 01:52 PM
Tyson's Avatar
9005?
Old Sep 16, 2004 | 02:02 PM
Default Re: (Tyson)
brand
Old Sep 16, 2004 | 02:05 PM
t0eKnEe's Avatar
Just buy any oem replacement, 9005 65w no need to spend $20-$30 on bulbs because they are blue or white.
Old Sep 16, 2004 | 02:07 PM
t0eKnEe's Avatar
Default Re: (t0eKnEe)
Just be careful when you break the 2 tabs in the bulb connector and dont touch the bulbs. Use a needle nose plyer
Old Sep 16, 2004 | 02:08 PM
301am's Avatar
what exactly IS the 9005 conversion can someone explain the whole deal about it to me?
Old Sep 16, 2004 | 02:13 PM
Default Re: (301am)
9006 is low beam
9005 is high beam
u replace u low beam bulbs with high beams. so that u have 2 sets of highbeams
Old Sep 16, 2004 | 02:15 PM
t0eKnEe's Avatar
Default Re: (301am)
9006 is the 88-91 civic/crx regular low beam bulb, 9005 is the high beam bulb. Now obviously the high beam bulb is alot stronger and connector for the bulbs are almost identical, just 2 plastic prongs on the 9005 connector which can easily be broken off apposed to a 9006 bulb, which has 1 prong. Just break off both prongs with a needle nose plyer and slide the 9005 bulb in the 9006 socket and wallah, your sporting a high beam bulb when you turn on your headlights.
Old Sep 16, 2004 | 02:37 PM
Synth124's Avatar
Default Re: (301am)
http://www.fourthgenhatch.com/9005.html
9005 higher watt bulb, with means it's brighter!
Old Sep 16, 2004 | 02:53 PM
crexer's Avatar
Default Re: (Synth124)
I did the 9005 conversion it took about a total of 5 minutes and I used the GE super white bulbs from walmart. They were 9 bucks a pop and have lasted for going on a year now. This is a good thing it looks really white and is a lot brighter than stock. Also for you guys worried about high brighting people just adjust your headlights a little lower
Old Sep 16, 2004 | 02:54 PM
jisu009's Avatar
Default Re: (kid-honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">I got it and I love it, nobody flashes me.</TD></TR></TABLE>
Same here..
Old Sep 16, 2004 | 03:35 PM
Slammed_S13's Avatar
I had it done in both my 90 Hatchs.. Had Eurolite bulbs that never burnt out.. **** they were bright
Old Sep 16, 2004 | 04:01 PM
onePOINTsix's Avatar
Default Re: (Slammed_CX)
i'll do it when wally world puts silverstars on sale again
