wiring harness question
Old Sep 15, 2004 | 10:54 AM
Mr.Death's Avatar
Default wiring harness question
What would be the best way on wiring up a d16z6 in a 90crx si using a p28 ecu:
A, Using the d16z6 wiring harness
B, Using a obdo/obd1 conversion harness.
I'm looking for the most straight forward and most effective way possible. I've done some research and know that if I use the the conversion harness I still need to do some wire splicing. If I use the d16z6 harness will I need to modify anything or is the install plug and play? Thanks for your time.
Rick
Old Sep 15, 2004 | 11:25 AM
Rywire's Avatar
Default Re: wiring harness question (Mr.Death)
def use the crx harness and a obd0-1 converter.
Ryan
Old Sep 15, 2004 | 11:33 AM
Mr.Death's Avatar
Default Re: wiring harness question (droppedcrxsi)
Why???? How will this benefit the install???? Deatails please.
Thanxxx
Old Sep 15, 2004 | 11:46 AM
smart monkey's Avatar
I would use the stock si harness and just get a jumper. jumpers are cheap now. for the time you would spend trying to figure out all the pins and stuff and going on ht asking people ?'s when you hit a issue the car can be running.
Old Sep 15, 2004 | 11:52 AM
kid-honda's Avatar
Always use the engine harness from the same car and model and modify how needed.
Old Sep 15, 2004 | 11:57 AM
Mr.Death's Avatar
Default Re: wiring harness question (smart monkey)
I'm using a p28 ecu which is the ecu that came with the d16z6. The z6 harness should connect with no mods. Shouldn't it????
Old Sep 15, 2004 | 12:38 PM
kid-honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Death &raquo;</TD></TR><TR><TD CLASS="quote">I'm using a p28 ecu which is the ecu that came with the d16z6. The z6 harness should connect with no mods. Shouldn't it????</TD></TR></TABLE>
No.
The engine harness connects to the body harness which then connects to the ECU.
You must use the stock engine harness and then make or buy a conversion harness and run the VTEC 4 wire 02 wires.
Old Sep 15, 2004 | 01:20 PM
bambam's Avatar
don't forget that if you convert to obd1, you're going to have to mate your obd0 crx si harness to that Z6 dizzy. U can make a small custom harness or use the good ol' cut n' solder method.
madswapper
Mar 28, 2005 07:51 PM
SOHCEK-Turbo
Aug 12, 2003 01:41 PM
fasterthenmost
Feb 26, 2003 06:46 AM
Attoir
Sep 4, 2002 11:33 PM
