A6 pistons in a DOHC Zc
What would be the pros/cons of doing this type of swap? Since the Vitara pistons are not reccomended in a Zc and pistons/rod combos are upwards of $600, I was just looking into other possibilities
btw here's that compression ratio calc link..
http://www.knology.net/~jediklc/D.htm
are u going NA, or FI ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">btw here's that compression ratio calc link..
are u going NA, or FI ?</TD></TR></TABLE>
I'm already force inducted. I blew cause I overheated. I'm not sure that I did any damage to the pistons but I have the head off so I guess I'm already in there so I might as well do the bottom. Plus I didn't like the way the #3 piston looked. (see Pic). Look closely at the bottom of the pic to see what I'm talking about.
some melted aluminum? ouch! 8.2 seems kinda low for FI. i know i know, should be low.. but there is such a thing of too low.. maybe 9:1 just mess around with that calc till u find something u like.
I just took the pistons out of the A6 block and they don't have that dome as the Zc's so that will definitely lower my compression. They're in pretty good shape so I think I'll use them with my Zc rods.
Is it safe to go .020 oversized?
You also said that 8.2CR is kinda low for FI, so why does Enydn sell these pistons?
Taken off the Endyn site:
ZC (43.8 cc) FI 75.5 mm 8.23-8.54:1 19.0 mm 267/80
NA (Low) 75.5 mm 9.68-10.13:1 19.0 mm 252/80
NA (High) 75.5 mm 10.52-11.16:1 19.0 mm 285/80
hatchinprogress
Nov 23, 2005 11:27 AM
