00 Si Front Onto Crx. Is it Bolt Up?
Old Sep 15, 2004 | 12:35 AM
Traction's Avatar
Default 00 Si Front Onto Crx. Is it Bolt Up?
Looking to do this front end conversion on my Crx just so to me it keeps a more updated look.
I just wanna know if its basically a bolt up swap and Im lucky or if a lot would be involved.
Any pics would be really sick
Would I need to do anything about the rad support? I would be using locking hood pins so a stock latch would not be needed.
Dont tell me not to do it please keep that to yourself, the SiR just isnt worth the $700 for wrap around corners and ahigher hood
Thanks guys
Old Sep 15, 2004 | 12:44 AM
ServiceAdvisor's Avatar
I really think your vastly underestimating the work involved in this project. I wish you all the luck in the world, since I'm sure you WILL need it. And, there is no way an 00 Si front end will simply 'bolt up' to any year CRX. But hey, maybe you can prove me wrong. - Darrell
Old Sep 15, 2004 | 12:48 AM
Traction's Avatar
Default Re: (DOHCZCCRXSi)
I just read a thread where the guy said he thought he was going to be in a **** load of work. Ended up completely bolting up
Im sure a few holes will need to be drilled for the new stuff and there moutning holes
Only problem I can foresee is the hieght of the headlights and how that would be done
Im very good with fiberglass though, you should see the moulding and shaving I did last year on my current crx, need something different
Old Sep 15, 2004 | 02:33 AM
Magick211's Avatar
Default Re: (Traction)
Ive never done the conversion nor have i seen it in person... But im almost 100% sure that it will not bolt up
Old Sep 15, 2004 | 05:04 AM
ProjektCRX2's Avatar
Default Re: 00 Si Front Onto Crx. Is it Bolt Up? (Traction)
well wut u can do is buy a whole front clip of the 00 si model and some how use it to fit onto the crx
Old Sep 15, 2004 | 05:43 AM
manson's Avatar
Default Re: 00 Si Front Onto Crx. Is it Bolt Up? (ProjektCRX2)
i also think it will not bolt up.
Old Sep 15, 2004 | 05:49 AM
FULL-RACE EP3's Avatar
Default Re: 00 Si Front Onto Crx. Is it Bolt Up? (manson)
Old Sep 15, 2004 | 06:30 AM
CRX Toad's Avatar
It is cool that you want to attempt something new but the SI is so round and CRX are square. I think it will look fairly unattractive but it is also your vehicle to do what you want. Not only that, the fenders on a CRX are small and short that the SI, I would think that the fenders and hood have the posibility of sticking up above the belt line and not being able to line of the body lines.
Best of luck to you...
Old Sep 15, 2004 | 07:01 AM
Judd's Avatar
Default Re: 00 Si Front Onto Crx. Is it Bolt Up? (CRX Toad)
your gonna get a lot of flames if you go thru with it but its your car do what you want... good luck
Old Sep 15, 2004 | 07:11 AM
LSvtec03's Avatar
Default Re: 00 Si Front Onto Crx. Is it Bolt Up? (Judd)
i saw a pic of someone's car that did that. in all honesty, it didn't look too bad. and i'm picky
but i'm also fairly sure it won't be a bolt on sitch.
Old Sep 15, 2004 | 07:31 AM
Aylla
Guest
Posts: n/a
Looks kind of awkward
Old Sep 15, 2004 | 07:41 AM
Jonathan_ED3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Traction &raquo;</TD></TR><TR><TD CLASS="quote">I just read a thread where the guy said he thought he was going to be in a **** load of work. Ended up completely bolting up
Post a link...because that's complete crap.
The cars aren't the same width, the nose is longer on the '00, etc etc etc.
It completely bolted up in the sense that you use bolts to hold all the pieces of crap together That doesn't mean it will bolt up to all the OEM mounting locations and look RIGHT doing so.
Old Sep 15, 2004 | 09:10 AM
CRX Toad's Avatar
Default Re: 00 Si Front Onto Crx. Is it Bolt Up? (GeniusB16A)
Look closely at the pic, the fender is higher on the A pillar and the belt line and the hood is higher and it just doesn't look right. I would love to see a pics of the car from straight over top of it I would bet the front is wider than the rest of the car as pointed out by Jonathan_ED3
It is different but I don't really care for it.....but to each there own. All I know is once you do that the value of my CRX's will go up cause it will be one more ruined CRX.
Old Sep 15, 2004 | 09:39 AM
Traction's Avatar
Well Ive got 8 pictures here where it looks absolutely perfect
I dont think it will "bolt up" but I dont think Ill have to cut anything either
Old Sep 15, 2004 | 09:45 AM
Full Race A6's Avatar
Ya If you guys find this thread I saw not to long ago either
It was a Crx with an 00 Si front, painted champ white, Ctr headlights, the guys if I remember said it was an easy swap for the front end
It really did look awesome and look like the updated crx and flowed really good
But it wasnt on a stock crx like above, it had the WW sides and door caps and the WW rear bumper along with some sort of small whale tail wing with completely reded out tails
Ill find the thread later maybe
Old Sep 15, 2004 | 09:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Traction &raquo;</TD></TR><TR><TD CLASS="quote">Well Ive got 8 pictures here where it looks absolutely perfect
I dont think it will "bolt up" but I dont think Ill have to cut anything either</TD></TR></TABLE>
Post them up.
If you don't know how, send them to me via AIM (sxybumjonathan) and I'll post them.
Old Sep 15, 2004 | 09:50 AM
bugsy's Avatar
[IMG][/IMG] 51281209
Old Sep 15, 2004 | 09:51 AM
bugsy's Avatar
Default Re: 00 Si Front Onto Crx. Is it Bolt Up? (bugsy)
http://www.cardomain.com/memberpage/621078/2]
somebody post that pic up NOW THATS HOT!!! so what its pink i like that
Old Sep 15, 2004 | 09:52 AM
bugsy's Avatar
oops heres the right one
Old Sep 15, 2004 | 10:00 AM
^^ Right.....
Im deifnetley finding my pics then,
Thats all I could find on that car, I was wrong about the CTR headlights I guess
Defetinely sexy
I know there is a red one with a fnacy hood but form a good angle kickin around
Modified by Full Race A6 at 11:22 AM 9/15/2004
Old Sep 15, 2004 | 10:01 AM
sinfultrends's Avatar
looks like that lady spent allot of money on her CRX to get it to look like that..
Old Sep 15, 2004 | 10:03 AM
Team 4's Avatar
Default Re: 00 Si Front Onto Crx. Is it Bolt Up? (Full Race A6)
I think that car looks good, but maybe in a different color.
Old Sep 15, 2004 | 10:11 AM
kid-honda's Avatar
I think changin body parts from other cars is kinda dumb but the JDM type r or 92-95 front end would probly match better.
Old Sep 15, 2004 | 10:29 AM
ironchef25's Avatar
Default Re: (kid-honda)
waste of time and money.. but if you like it.. hey more power to ya.. good luck..
Old Sep 15, 2004 | 10:40 AM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Default Re: (ironchef25)
Yeah dude mine bolted right on, no mods at all.
