Okay I have some paint Questions?
Old Sep 14, 2004 | 09:34 PM
Shant03's Avatar
Default Okay I have some paint Questions?
Okay So i have a 96 Accord V6 LX as some of you know. And its a champaign color.. and its got alot of scratches and the rear bumper is going to be replaced. Now I am only willing to spend about $500 MAX! on a paint job but i want it to be the same color and i want a great paint job so it doesnt like rust in a matter of 6 months i want something that will last me atleast 3-4 years.
Old Sep 15, 2004 | 03:44 AM
Filthy Focker!'s Avatar
Default Re: Okay I have some paint Questions? (Shant03)
So what is your question?
fs
Old Sep 15, 2004 | 06:12 AM
90accorddx's Avatar
You can try some onsight paint repair companies i work for a rental car place and there always there they specialize in just repainting one or two panels and they are pretty reasonably priced the guy that does ours charges 150 a panel
Old Sep 15, 2004 | 06:42 AM
Confuc1ous's Avatar
a 'good' $500 paint job really doesnt exist, your best bet, especially if you want your paint to go back to looking how it did when the car was brand new, is to try and save something like $2000, that is a more realistic figure, see, what most people dont realize is that the stock paint job that comes on your Honda isnt all that bad, and in replacing it, can cost you, so take that into consideration...
Old Sep 15, 2004 | 08:54 AM
Shant03's Avatar
Default Re: (Confuc1ous)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Confuc1ous &raquo;</TD></TR><TR><TD CLASS="quote">a 'good' $500 paint job really doesnt exist, your best bet, especially if you want your paint to go back to looking how it did when the car was brand new, is to try and save something like $2000, that is a more realistic figure, see, what most people dont realize is that the stock paint job that comes on your Honda isnt all that bad, and in replacing it, can cost you, so take that into consideration...</TD></TR></TABLE>
would a company like macco or those other known companys be able to do this? like match the paint
Old Sep 15, 2004 | 09:28 AM
95ACEX's Avatar
MAACO jobs aren't consistent. Some people recieved decent jobs from MAACO, some people recieve crappy ones. I say either save and get a good paint job, or do what another user said and have some specific panels repaired.
Old Sep 15, 2004 | 09:42 AM
Shant03's Avatar
Default Re: Okay I have some paint Questions? (95ACEX)
anyone know any other decent shops around in Socal
Old Sep 15, 2004 | 10:20 AM
fw190bvi's Avatar
your best bet is to save the money....even if only some panels are painted, because of atmospheric conditions during the painting process, the surfaces will NEVER me 100% exact matches of each other.....
is your car cashmere silver ???
Old Sep 15, 2004 | 12:57 PM
Jeff_Chicago's Avatar
Default Re: Okay I have some paint Questions? (fw190bvi)
Save some money and get a good paint job! You'll thank yourslf when your paint actually stays on the surface!
Old Sep 15, 2004 | 02:13 PM
philadd's Avatar
Default Re: Okay I have some paint Questions? (Jeff_Chicago)
good paint jobs are expensive... cheap places don't prep the body well enough, use cheaper paint, don't spray as many coats of paint, or clear coat for that matter...
having friends that own body shops, i can tell you... for a good paint job, expect to spend a bare minimum of $1200, but more likely $1500-2000. (for painting an entire car)
now, knowing you only want to spend $500 max, if they scratches aren't too deep, they can be buffed out by a body shop without repainting. i forgot what the stuff my friend's place uses, but it's amazing. it took all the scratches out of my car in a matter of minutes. we just put it on like a wax, then buffed it off. a good shop can paint just a bumper for maybe around $200. be warned though, the older your car and the more sun it has seen, the higher the chance your original paint has faded to some degree.
Old Sep 21, 2004 | 08:03 PM
Shant03's Avatar
Default Re: Okay I have some paint Questions? (philadd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">good paint jobs are expensive... cheap places don't prep the body well enough, use cheaper paint, don't spray as many coats of paint, or clear coat for that matter...
having friends that own body shops, i can tell you... for a good paint job, expect to spend a bare minimum of $1200, but more likely $1500-2000. (for painting an entire car) </TD></TR></TABLE>
would this mean they would be painting the inside door panels n **** too?
Old Sep 21, 2004 | 09:09 PM
-RedneckDave-'s Avatar
Working
If you want a good paint job from a place like MAACO then you need to do all your own prep work and make sure the car is perfect before it goes there and chances are it will turn out much better than most expect. Try searching in the appearance forum and you should find some threads about cheap paint jobs.
christianc5692
Paint and Body
10
Aug 30, 2010 06:50 AM
Kirk@SyndromeAuto
Paint and Body
Nov 12, 2007 08:53 PM
Captain Flaps
Dec 19, 2005 08:30 PM
brasilracing
19
Jul 29, 2002 11:23 AM
HBCthugg
Apr 15, 2002 08:07 PM
