quick question about code 14 iacv
Old Sep 14, 2004 | 09:00 PM
achanjr's Avatar
Default quick question about code 14 iacv
this had popped up on my cluster when i did the service check.
i had diagnosed close to everything, and found there was a crack in my antifreeze line going to the throttle body. when i bent it a little, i could hear air psssssss-ing out, followed later by a little trickle of antifreeze. could this be the problem plaguing me for the last 2 weeks of diagnosis? i haven't been able to work on my car since i found out this hose was leaking.
thanks in advance
Old Sep 14, 2004 | 11:15 PM
hatchi's Avatar
Default Re: quick question about code 14 iacv (achanjr)
change the hose then reset the ecu and see if it still pops up. If it does then clean it out
Old Sep 14, 2004 | 11:24 PM
achanjr's Avatar
oh i forgot to mention that i had the fluttering idle problem at 1500...
could this be the cause? i'm certain my iacv works.
Danny Rogers
Mar 31, 2019 02:35 PM
jaskuloski97sh
Oct 11, 2007 10:56 PM
w0ng_sta
Jul 10, 2006 07:09 PM
UNKNOWN_MEMBER
Jun 27, 2005 08:15 AM
jackalpupz
10
Jan 8, 2005 10:57 AM
