OBD0 b18c1 knock sensor question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spcrxracer »</TD></TR><TR><TD CLASS="quote">I have a 91 crx dx with B18c1 wired up obd0. <FONT COLOR="red"> Does OBD0 have a knock sensor??</FONT>
You should ask that question by listing what ECU you're running with the setup. If you're using a stock <U>DOHC</U> VTEC ECU, regardless if it's OBD-0, OBD-1 or OBD-2, they all look for a knock sensor. If you're running some jenky way using a LS or stock SOHC ECU with a MSD box to activate VTEC, then no that ECU doesn't look for a knock sensor.
toyotat100
Oct 15, 2014 07:57 PM
