Type-S Motor in my Si
So, finally spun that rod bearing in my h23
I figure its time to go h22...but not just any h22.. the fabled Type<FONT COLOR="red">S</FONT>
so in a couple months i'll have enough money for the swap.
in searching this is the most helpful thing i found: (credit: Finest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest »</TD></TR><TR><TD CLASS="quote">
Things you'll need to work in an OBD-I environment:
OBD-I distributor
OBD-I P13 ecu
H22a1 injectors *peak and hold*
USDM H22a1 fuel rail
Everything else is a bolt in. Mounts/axles/etc. Wire in the appropriate VTEC wires and you'll be good to go. Just remember to use 92+ octane, since you're running high compression.
Now... is there anything else i need to worry about (do i actually need all of that)?
i am going to go high-flow cat/test pipe, so i wont have to worry about my exhaust fitting strangely.
I also need to know what's up with wiring.. is that a huge issue or what? can anyone offer a quick: 'what to look for'?
I'm looking to buy from H-Motors Online. I've read that these guys are the most reputable. And correct me if i'm wrong but this is the euroR H22A7 with the T2W4 Tranny.
OBD-I distributor
OBD-I P13 ecu
What are your plans for this motor ?? If you are just going to drop it in then maybe get a header and intake, that sure go for it.
If you want aftermarket valvetrain, cams etc this swap will be a waste of money.
oh and also, as i recall the type S has atts, so good luck with that whole problem. damn that atts unit.
My plans are just to tune it with a VAFC, already have a CAI. I plan to buy a header, maybe your basic greddy and leave it all alone.
The type S that i'm looking at is the Accord Type-R japanese Type-S with the U2Q7 tranny..that has LSD and no ATTS to deal with.
The Type S cams and Pistons are enough for me in terms of internals.
Can someone pllllease confirm that list of things ill need to work with my OBD-I Si?
just to straighten things up:
Accord Type R engine: H22A7 + U2Q7 tranny with LSD- met in Europe
It has the same internals as Prelude Type S engine.
EuroR with T2W4 comes from Japanese Accord.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Waiting For My Lude »</TD></TR><TR><TD CLASS="quote">I heard rumors the the type-s is a h22a w/ alot more problems, but thats just what I heard</TD></TR></TABLE>
You heard wrong.
You heard wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq »</TD></TR><TR><TD CLASS="quote">just to straighten things up:
yep you're right i mis-spoke i meant the TypeR EDM motor.
so i can't use the injectors, fuel rail, distributor, or ecu that comes with the motor?
and also less mileage. i'm not saying its 100% worth it but it'd be nice.
if its possible, why not do it? I'd probably spend 1 grand getting a hold of a type-s valve train and pison/rod setup with the install.. i also plan to sell my h23 parts to offset the cost.
plus i've read that well tuned h22a7's produce some nice numbers- and ive been told that TypeR tranny is worth it.
syntax.
Jun 13, 2005 09:32 AM
