Custom Radiator Hose -AN conversion stuff
Old Sep 14, 2004 | 07:17 PM
stizzit's Avatar
Default Custom Radiator Hose -AN conversion stuff
For my new setup, I need to chop off the lower radiator hose pipe on my fluidyne for fitment. I plan on welding a plate in its place and using a -12an fitting on the side of the radiator.
The problem is, how the hell do I connect the other end to the thermostat housing?
My idea:
Weld a plate over the housing inlet, drill and tap for 3/4" pipe and use a -12AN to 3/4NPT adaptor. Does anyone have any better solution?
IF thats the way I go, I need to get a hold of some 1.3" dia solid aluminum bar stock - anyone got any in small quantities?
Old Sep 14, 2004 | 07:24 PM
B18C1CYA's Avatar
Default Re: Custom Radiator Hose -AN conversion stuff (stizzit)
just weld the an fitting to the housings, thats how i have seen it done
Old Sep 14, 2004 | 07:46 PM
stizzit's Avatar
Default Re: Custom Radiator Hose -AN conversion stuff (B18C1CYA)
not a bad idea actually!!!
pentaq
Welding / Fabrication
12
Sep 19, 2008 10:35 AM
steveharrmr23
Aug 19, 2008 03:25 PM
crx90rcr
Aug 5, 2005 02:49 PM
lucasbkellner
10
Nov 15, 2004 04:13 PM
01ITR#700
May 20, 2004 02:22 PM
