gm syncromesh for 95 Prelude Vtec Good or bad ?
I have heard this stuff is the best. Whats the general concensus here? I picked up two quarts. Anything bad that can happen ?
Anyone use this stuff ? Compared to Honda MTF ? Better ?
I guess trying to be safe Hate to F up a Perfectly good tranny Slight grind into 3rd at vry high rpm's and the Normal fifth gear factory grind.
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luder22 »</TD></TR><TR><TD CLASS="quote">I have heard this stuff is the best. Whats the general concensus here? I picked up two quarts. Anything bad that can happen ?
Thanks </TD></TR></TABLE>
Well there have been two other threads that have popped up the past couple of days with nothing but good things to say about it. You could also search, I'm sure there are 50+ threads about syncromesh.
i ran it in my tranny for 6 months+ without any problems until i got my new tranny(for other reasons...), however i would only run syncromesh when the tranny problem gets so bad that you cannot/its very hard to shift or grinding is really bad, otherwise, if there are slight grinds then just stay with honda mtf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93vtec ATL »</TD></TR><TR><TD CLASS="quote">you need to get it from a GM dealer</TD></TR></TABLE>
Nope. Go to AutoZone and pick up some Pennzoil Synchromesh. It's the SAME stuff, just A LOT cheaper. $5.00/quart.
You need 2 quarts if you have a vtec prelude like mine. I paid $10 per quart at the local dealer.
I just dont want to mess up anything by using it Im gonna put it in tomorrow so i figured id put it out ther and see if anyone had anything bad to say like dont use it it messed up my tranny. I guess not
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR »</TD></TR><TR><TD CLASS="quote">anybody on here using the GM synchromesh
with the m2b4 tranny?</TD></TR></TABLE>
snowseeker
Feb 5, 2009 12:36 PM
