Mini-Me Is dying! Whats up ?
Old Sep 14, 2004 | 05:48 PM
drnovascotia's Avatar
Default Mini-Me Is dying! Whats up ?
Alright, so the Mini me has been acting up on and off. As of late, half the time she'll run perfect. The other half however, whenever I put out the clutch or come to a stop . .the idle will go down and eventually die. This happened when sitting at a light today, and when coming off the highway I put the clutch in and looked down two seconds later and she was dead, lol. But other times, she'll idle @ 900rpm's like a rock!
So, I did the z6 swap stayed OBD 0, new cap rotor plugs wires o2 sensor, etc. I turned the idle up a hint. Looked for vacuum leaks. I'm officialy stumped.
No ecu codes I reckon
Anyone run across this or have any ideas? HELP! I need her back on the road for good in 2 weeks!
THANKS
Dr.
Old Sep 15, 2004 | 09:13 AM
Default Re: Mini-Me Is dying! Whats up ? (drnovascotia)
come on now, all these swappers and no hints ? I refuse to believe that!
Dr.
Old Sep 15, 2004 | 09:21 AM
crxgator's Avatar
try cleaning your IACV, its on the back of the intake manifold with a plug attached to it...i believe its two 12mm bolts...
Old Sep 15, 2004 | 10:41 AM
crx_88_si's Avatar
whats the fuel level lke when this happens?
Old Sep 15, 2004 | 11:53 AM
Default Re: (crx_88_si)
The fuel level doesn't seem to be an issue, happened when I was almost empty and happened couple nights ago after I had just filled up.
I'll try cleaning that now, we'll see how it goes.
Dr.
Old Sep 15, 2004 | 05:26 PM
Default Re: (drnovascotia)
I tried cleaning out that, and cleaned the throttle body, didn't change anything. Seems more like a intermittent electical or hose problem, but I haven't a clue.
Any help ?
Dr.
Old Sep 16, 2004 | 08:48 AM
1QWKCRX's Avatar
The IAVC was my call to. However they do go bad (since our cars are 10-14
years old) you may need to find a new one or at least newer one at a junkyard.
Make sure you spray it out with throttle body cleaner!!!
And get a new "8" shaped rubber gasket at the Honda dealer.
Old Sep 16, 2004 | 12:30 PM
88turdbucket's Avatar
what about an intake leak?
Old Sep 16, 2004 | 06:50 PM
Default Re: Mini-Me Is dying! Whats up ? (88turdbucket)
I looked at the cheap Ebay intake, but didn't see anything. The filter is dirty though
and I have no clue about the IAVC . . but it seemed fine, how do I know if it's not ?
Dr.
ftrms
Apr 14, 2010 05:58 PM
mattsthru
May 27, 2007 06:19 AM
sykotic
Jul 1, 2006 08:55 AM
clemsonteg
Dec 28, 2005 10:07 AM
