90-93 Integra Sway Bars on 88 CRX?
Old Sep 14, 2004 | 03:43 PM
sir91's Avatar
Default 90-93 Integra Sway Bars on 88 CRX?
I did a search on this topic but no one had a definate answer.
I would like to know if 90-93 Integra sway bars will fit an 88 CRX? Please be as specific as possible on how to make them work.
Thanks in advance
Old Sep 14, 2004 | 04:28 PM
Tyson's Avatar
Default Re: 90-93 Integra Sway Bars on 88 CRX? (sir91)
the fronts are shaped perfectly same, youll just need the bigger (22mm) bushings with the bar, and perhaps the C bracket. i dont think the rears are any different than the Si actually.
while the DA bar is 22mm, im guessing it is still hollow since its considerably lighter than a ST 22mm front bar. but shouldnt matter too much, since the effects of torsion are multiplied by the square of radius.
Modified by Tyson at 5:44 PM 9/14/2004
Old Sep 14, 2004 | 04:37 PM
sir91's Avatar
Default Re: 90-93 Integra Sway Bars on 88 CRX? (Tyson)
Thanks for your reply .
The ones I am probably getting are the ST's which are pretty beefy. I was mostly worried about the rear, so if anybody can give more input I would appreciate it.
stevescivic
Aug 29, 2005 04:52 PM
trooper0641
Feb 9, 2005 03:46 AM
sir91
Sep 14, 2004 04:37 PM
ShagginJet
Aug 27, 2003 10:00 AM
juicy.koreans.suck
Jun 5, 2002 06:58 AM
