Need new valves for H23???
Old Sep 14, 2004 | 03:42 AM
BoostedH23Accord's Avatar
Default Need new valves for H23???
So I was driving home after dropping my son off and I heard a pop then the car just died. Turns out the Crank bolt backed out and caused timing to jump I don't know how many teeth. Bottom line is the valves are bent I put it back together and the car idles like utter crap. Would I be better off just replacing the whole head or does anybody know where I can get valves cheap?
Thanks for the help guys
Old Sep 14, 2004 | 07:21 AM
bump
Old Sep 14, 2004 | 07:25 AM
EFz6er's Avatar
Default Re: (BoostedH23Accord)
I think the valves themselves are pretty cheap
Old Sep 14, 2004 | 07:52 AM
yohan's Avatar
is replacing valves pretty much a DIY mod ??
Where does the "3 angle valve job" come into play in something like this,, and would it be needed in the above circumstance? ...
Old Sep 14, 2004 | 08:24 AM
Default Re: (yohan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yohan &raquo;</TD></TR><TR><TD CLASS="quote">is replacing valves pretty much a DIY mod ??
Where does the "3 angle valve job" come into play in something like this,, and would it be needed in the above circumstance? ... </TD></TR></TABLE> It's not a hard job just that the head and (EVERYTHING) else needs to be taken off to get the valves out. A valve job would be great that that requires specialized tools.
I will probably just replace and seat them to get a good seal.
Old Sep 14, 2004 | 08:28 AM
98TypeSH's Avatar
Just get some OEM valves, and some new seats and away you go. Dont forget to use assembly lube and what not when putting everything back together. You may need a valvespring compressor as well. Check out the helms on head assembly
Unless you can find some uber deal for a new head with low mileage, just swap the valves and new seats would be good idea if they are cracked or worn.
Old Sep 14, 2004 | 08:41 AM
Default Re: (98TypeSH)
I got a pretty good deal on a head. But cant find OEM or OEM replacement for under $400 I'm like WHOA!!!!! so if you you where I can find them let me know because as it stands nobody has H23 valves except Honda
Old Sep 14, 2004 | 08:55 AM
98TypeSH's Avatar
Then i would suggest buying a head from someone with low mileage for about the same price maybe a little cheaper depending on how bad they want to ditch their h23. That seems about the only option you have. Sad that you have to buy a whole new head because of damn valves. You can get h22 valves all over the friggin place
Old Sep 14, 2004 | 09:09 AM
Almost makes me want to swap to an H22 head instead.
Old Sep 14, 2004 | 09:12 AM
98TypeSH's Avatar
i feel another h23 vtec coming. I dunno if you really want to turn your car into a money pit, totally up to you.
Old Sep 14, 2004 | 09:45 AM
What do you mean, it already is a money pit!!! LOL
Old Sep 14, 2004 | 09:48 AM
98TypeSH's Avatar
Wait till you spin a bearing or destory a crank. lol i agree with you. Im sick of my damn money pit. wanna buy it?? lol. I just wanna get something i can get in and drive. no more slow for speed bumps. no more having to park like 2 blocks away because i dont want someone to ding the crap out of it. ah well.
low milage h23 head, or h22 head with new stuff. good luck on your decision.
Old Sep 14, 2004 | 10:11 AM
Low milage H23 head cheaper by the dozen... No pun intended
laboyon
Aug 14, 2008 05:08 PM
adam94lude
Oct 16, 2005 03:26 PM
flip1199
Jun 14, 2005 05:43 PM
polishprinze
Jan 9, 2005 05:45 PM
cxSHOE
Mar 29, 2004 05:20 PM
