KYB AGX Question. (those who have them)
Old Sep 13, 2004 | 09:05 PM
eclypzex's Avatar
Default KYB AGX Question.
OK, i ordered some KYB AGX from ebay, received them, but 2 of them don't have any way of adjusting them. Can someone who owns them help me out? i thought they were adjustable?
-albert
Modified by eclypzex at 10:17 PM 9/13/2004
Old Sep 13, 2004 | 09:09 PM
ProJectCvic's Avatar
Default Re: KYB AGX Question. (eclypzex)
are you sure? they should be on the top of the metal rod. Some version of agx came with the adjustable **** on the side.
Street Ghost's Avatar
What year, for what car? Do you have pics of them? The AGX's that I used to have ad adjusting ability on all four of them. They adjust at the top of the shocks.
Old Sep 13, 2004 | 09:10 PM
bushfreakz's Avatar
i ordered mine off ebay.. all four have 4 way adjustable ***** on the top of the piston rod that have to be pushed in and turned then released..
other models have **** on side.. and i believe the ones that dont have ***** are factory replacements
Old Sep 13, 2004 | 09:11 PM
eclypzex's Avatar
Default Re: KYB AGX Question. (JDM Ninja)
ok, its a 98 civic hatchback, i received all 4. 2 of them have a **** at the bottom and like a fork missing the middle stick and the other don't have taht piece nor a ****, can someone help me out?
eclypzex's Avatar
lemme check for the top adjusting..
Old Sep 13, 2004 | 09:14 PM
allmotorEG-SI's Avatar
better hope that they sent you the right ones.
eclypzex's Avatar
ok, i have the adjusting on the top but on those there is no fork to like hook up to the arm? i put suspension on my previous car but this is different can someone tell me?
Old Sep 13, 2004 | 09:17 PM
do all 4 look the same? The fronts should be a round at the bottom to plug into the top of a fork. The rears are supposed to have a fork to go around the LCA.
Old Sep 13, 2004 | 09:19 PM
eclypzex's Avatar
Default Re: (allmotorEG-SI)
no, 2 look the same 2 are "missing" the fork to attach themselves? is something wrong here? did i get a different year set of shocks?
Old Sep 13, 2004 | 09:20 PM
bushfreakz's Avatar
no in the fron of the car you have a fork that has a hole in it already.. you slide the shock into it and it clamps down with a bolt
Old Sep 13, 2004 | 09:22 PM
bushfreakz's Avatar
Default Re: (bushfreakz)
it sounds like you have the right stuff
front and rear shocks are different.. plus the fronts you must note when you do them.. that there are brake lines that srew into the shock.. so there is a right and left to them..
Old Sep 13, 2004 | 09:24 PM
eclypzex's Avatar
i dont think im making myself clear. shocks look like this: http://www.leda.com/images/civic.jpg
2 of each. only the ones without forks have adjustment on rod. anyhelp? 98 civic hatchback.
Old Sep 13, 2004 | 09:26 PM
I think you goy the wrong shocks.
Old Sep 13, 2004 | 09:30 PM
eclypzex's Avatar
damn.. alright thanks.
Default Re: (eclypzex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eclypzex &raquo;</TD></TR><TR><TD CLASS="quote">i dont think im making myself clear. shocks look like this: http://www.leda.com/images/civic.jpg
That's pretty much how the bottom of the shocks are supposed to look. I think you got the right ones. The ones that you keep saying that are missing the "forks" go in the front, and the ones with the "forks" go in the rear. Why don't you just show us a picture of the actual ones you have?
Do two of your shocks look like the one in the picture here: http://cgi.ebay.com/ebaymotors...33590
JforJonathan's Avatar
the front struts use your existing fork. the back has the "fork" built in to go onto your lowercontrol arm. hope this helps.
Old Sep 13, 2004 | 09:34 PM
But he says two of them don't have anything to allow for adjustment on them. Thats not right.
Old Sep 13, 2004 | 09:38 PM
ej1 pilot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorEG-SI &raquo;</TD></TR><TR><TD CLASS="quote">But he says two of them don't have anything to allow for adjustment on them. Thats not right.</TD></TR></TABLE>
he figured that part out already
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eclypzex &raquo;</TD></TR><TR><TD CLASS="quote">ok, i have the adjusting on the top but on those there is no fork to like hook up to the arm? i put suspension on my previous car but this is different can someone tell me?</TD></TR></TABLE>
Reading owns j00..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eclypzex &raquo;</TD></TR><TR><TD CLASS="quote">ok, its a 98 civic hatchback, i received all 4. 2 of them have a **** at the bottom and like a fork missing the middle stick and the other don't have taht piece nor a ****, can someone help me out?</TD></TR></TABLE>
Old Sep 13, 2004 | 09:41 PM
eclypzex's Avatar
Default Re: (JDM Ninja)
lol.. thanks guys, so the fronts use the existing control arms? cause i went to kyb.com and the part #'s match perfectly.
Old Sep 13, 2004 | 09:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eclypzex &raquo;</TD></TR><TR><TD CLASS="quote">lol.. thanks guys, so the fronts use the existing control arms? cause i went to kyb.com and the part #'s match perfectly.</TD></TR></TABLE>
Yeah, you use the existing forks for the front.
Old Sep 13, 2004 | 09:44 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
it's really not rocket science.. you should be able to figure it out on your own from here.. good luck.
Old Sep 13, 2004 | 09:51 PM
it also helps to have an impact gun for getting some of he bolts off. They can be a bitch.
Old Sep 13, 2004 | 11:47 PM
GRAVEDIGGER's Avatar
96 hatch, front are on top. rear have a ****.
