ITR crank in a ls block???
Old Sep 13, 2004 | 07:20 PM
evilone's Avatar
Default ITR crank in a ls block???
Will i have any issues with a itr crank in a ls block???If not, any advantages or dis advantages???
Old Sep 13, 2004 | 07:35 PM
97L-esVeeTeg's Avatar
Default Re: ITR crank in a ls block??? (prostockcrx)
you can do it, but why? the itr block already has oil squiters and a block girdle, the ls doesnt. And if you already have the ls block, just keep it, and take advantage of the longer stroke (89mm from 87.2 for the ITR). The only benefit i can see is the slightly better r/s ratio of the ITR 1.58 (i think) instead of 1.54 for the ls, which isnt that big of a deal.
Old Sep 14, 2004 | 04:10 AM
NAstreetEH2
Guest
Posts: n/a
advantage...you can say you have a heavy *** ITRRRR crank in your engine
disadvantages: loss of power, waste of money, doing work for nothing
evilone's Avatar
Default Re: ITR crank in a ls block??? (97L-esVeeTeg)
Well my deal is i have a Ls block that is sleeved and bored .20 over, but no crank. I also have Arias 12.5 to 1 pistons(2 sets .20 over). Than i have a 96 jdm ITR in my car. Basically i was thinking I'll just use the itr crank but it seems I'd be better off just buying a new crank and selling the itr.
Old Sep 14, 2004 | 04:11 AM
evilone's Avatar
Any one ever use the eagle lightweight cranks?
Old Sep 14, 2004 | 04:17 AM
NAstreetEH2
Guest
Posts: n/a
eagle cranks are designed improperly.
if you really want an aftermarket crank..go with crower.
but i'd still suggest getting an OE LS/b20 crank
Old Sep 14, 2004 | 04:19 AM
evilone's Avatar
Default Re: (NAstreetEH2)
Thanks for the info, i'll give crower a call
Old Sep 14, 2004 | 04:22 AM
evilone's Avatar
Default Re: (prostockcrx)
One more question, what would be the better oem crank, ls or b20?
Old Sep 14, 2004 | 04:33 AM
NAstreetEH2
Guest
Posts: n/a
they're the same, as far as i know
both are forged cranks with 89mm storke
Old Sep 14, 2004 | 04:59 AM
evilone's Avatar
Thanks again
Old Sep 14, 2004 | 05:44 AM
NAstreetEH2
Guest
Posts: n/a
no prob
good luck on the project
Old Sep 14, 2004 | 07:04 AM
hybrid_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAstreetEH2 &raquo;</TD></TR><TR><TD CLASS="quote">advantage...you can say you have a heavy *** ITRRRR crank in your engine
disadvantages: loss of power, waste of money, doing work for nothing</TD></TR></TABLE>
Never knew this! I have heard it the other way around; LS crank and rods in an ITR!
Old Sep 28, 2004 | 09:06 PM
Muckman's Avatar
Moderator in Chief
Default Re:
How much does a ITR crank weigh?
a GSR weighs 35lbs
and a LS weighs 34.5lbs
Old Sep 28, 2004 | 09:11 PM
irev210's Avatar
Default Re: Re: (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">How much does a ITR crank weigh?
a GSR weighs 35lbs
and a LS weighs 34.5lbs</TD></TR></TABLE>
I cant remember ~2lbs i think?
search in the ITR forum, they had pictures etc comparing
thegeezerkid
Nov 12, 2008 10:23 AM
tofu-eg
Jun 1, 2008 03:09 PM
Teamdiesel
Apr 14, 2007 05:31 PM
gmacarize
Jul 26, 2006 08:16 PM
B20Monster
May 18, 2004 07:46 PM
