Code 20, CRX Si...
Old Sep 13, 2004 | 06:06 PM
iphatcrxi's Avatar
Default Code 20, CRX Si...
what exactly it this code, i know its with electrical load, but what the hell is that? what do i check and how do i fix it...
Old Sep 13, 2004 | 06:24 PM
iphatcrxi's Avatar
Default Re: Code 20, CRX Si... (iphatcrxi)
bump
Old Sep 14, 2004 | 10:49 AM
iphatcrxi's Avatar
help ...
Old Sep 14, 2004 | 10:52 AM
bambam's Avatar
i've had the problem b4...
seems there is an overload somewhere prolly a bad ground or something grounding out.
check all your factory grounds: valve cover, tranny, thermostat....if they're corroded...sand them down or replace them.
Old Sep 14, 2004 | 11:23 AM
EL Vap133's Avatar
https://honda-tech.com/zerothread?id=875713
Old Sep 14, 2004 | 01:53 PM
tilt's Avatar
i had the ELD code 20 before. I followed the helms and found that the voltage wasnt right on one of the tests. I just replaced the whole fuse panel under the hood and it fixed the problem.
Old Sep 14, 2004 | 03:46 PM
4DRmafia's Avatar
it basically ur grounds and i had the same plm from 4 weeks ago and i just sanded down my ground wire and the plm is gone
dracocrx
Apr 10, 2009 05:47 AM
integra_mike
Mar 9, 2007 09:02 AM
integra_mike
Feb 23, 2007 05:54 AM
digital sol
May 19, 2006 07:50 AM
lsvtec42
Dec 19, 2001 10:11 AM
