del sol suspension
looking at a del sol w/ b16 great price
is the suspension setup the same as 92-95 civic?
i am looking to make this a track car and would like to purchase omnipower coilovers for it. however, i dont see a listing on their website for the del sol.
thanks in advance for any input/advice
I thought it was the same suspension.....Im sure some sol owners will chime in soon.... whats his name Dirty Sol?? He would prolly know for sure
It's basically the same as a 92-00 civic setup. Only since it has a targa top, Honda had to reinforce the car more. So unfortunately you'll have a lot of body roll. Where are the other Sol people at?
It is the same suspension as the 92-00 Civics when i ordered my lowering kit with new shocks struts and springs it was the exact same kit as the civic. Some ppl i talked to on e-bay told me different when i wanted to order mine but after some research i found it was the same so.
thanks for all the replies... i am really looking forward to tracking this car....
i will do a search, to see who makes a sway bar kit to cut down on the body roll.... i would think hotchkins, or eibach, etc... would make something...
Theres a ton of ppl who make them for the sol, E-bay has some cheapies listed all the time i belive for about $35 but keep in mind most of those arent the best for your car. So check out E-bay you can get a lot of good stuffs for your car on there for far less then retail
is this sol with the b16, has it had a swap or was that the orginal engine?
On the del sol VTEC (stock with a b16a3) had a rear swaybar on it. Nice thing about that is, you can swap on any swaybar from an integra without switching your LCA's. If it is an SI or S and you want to put, lets say a ITR 22mm rear sway on, you need to swap out your LCA's. Other then that, it is the exact same suspension as the integra/5th gen civic.
geez this thread is full of a lot of good information and a lot of MISINFORMATION
just becasue the chassis is reinforced does not mean more body roll.....if anything there would be less.
you can use any suspension setup off of a DC2 non R and any civic 92-95 without any modification. if you are looking for less expensive but good performing coilovers check out hte ones available on http://www.memoryfab.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolSiR »</TD></TR><TR><TD CLASS="quote">or you can change the rear lca's and use the dc2 type r shocks. If you're gonna track it, get some good coilovers!</TD></TR></TABLE>
Really, its almost not needed. Pretty much all coilovers that are made for the DC2r are also made in EG's versions.
However, I did go with ITR rear LCA's with Tein HA coilovers since the HA's were not available in EG suspension.
JDMAF
Feb 10, 2011 03:56 PM
ej6kid
Oct 26, 2010 03:42 PM
deadlock32
Mar 2, 2006 07:36 PM
