GARAGE SALE!! Tons of '99-'00 Si (B16A2) parts, stock and aftermarket (sorry 56k)
ok I'm gonna just post solid low prices... lets get this started...
SOLD - turbo (I'll include send and return lines)
$230 - log mani
$75 - wastegate with dump tune if you want it
$220 - CF clutch
$220 - crank
$130 - A/C
$500 - b16 head
$50 - b16 cams with gears (sale pending)
$80 - GSR radiator
$75 - inake mani with TB (TB sold)
$55 - intake without TB (I have two)
$135 - timming belt kit for b16 (new in box) (sale pending)
$25 - oil pump
$20 - water pump
$25 - stock oil pan
$50 - stock b16 connecting rods
$50 - stock injectors
$30 - valve cover (sale pending)
$30 - fuel rail and reg
$75 - Stock B16 flywheel
***all shipped***
(in US)Drag 3 manifold...
Delta Wastegate (7lb spring)... I'll include the dump tube if its wanted...
Knife edged LS crank (89mm stroke), also was balanced and micro polished...
GSR radiator...
B16A2 stock head (30k miles on it)...
CenterForce Dual friction clutch (less then 3k miles on it)...
OEM spec b16 timming belt kit **Brand New** sells for $170 asking $135 cause thats what I loose on re-stocking fee if I just return it... my loss your gain
includes:
-Timming belt
-Tensioner/spring
-Water pump
'99-'00 civic si A/C complete...
here's the rest of the parts I have for the A/C, everything is there except the evaporator, and one hose (hard line)...
b16 intake mani with TB...
stock (b16a2) cams and cam gears...
stock (b16a2) fuel rail and fuel regulator
I also have (for b16):
- 270cc stock injector set
- Oil pumps (qty 2)
- Water pump (qty 2)
- Stock connecting rods set
- Oil pan (not tapped)
- Stock valve cover
- Stock flywheel (qty 2)
Lots of parts for those who are trying to put the car back to stock
I'm ready to make some good deals so MAKE OFFERS!!!
also here's my vouch thread...
https://honda-tech.com/zerothread?id=986938
Modified by turbosi03 at 1:15 AM 9/15/2004
Modified by turbosi03 at 10:42 AM 9/27/2004
Modified by turbosi03 at 11:56 PM 9/28/2004
8krdline
May 2, 2008 05:21 PM
turbosi03
Oct 11, 2004 09:40 AM
