The difference between a 35mm , 38mm, 40mm wastegate??
Old Sep 13, 2004 | 03:39 PM
CrazyHB's Avatar
Default The difference between a 35mm , 38mm, 40mm wastegate??
what is the difference between differnt size wastegates? someone explain in detail please advantages and disadvantages of bigger wastegates ect.
Old Sep 13, 2004 | 03:48 PM
Boostage's Avatar
Default Re: The difference between a 35mm , 38mm, 40mm wastegate?? (CrazyHB)
those are the sizes. the bigger the wg is the stronger it is at holding low boost with a big turbo. because it can physically bypass more exhaust gas.
Old Sep 13, 2004 | 03:51 PM
Ben Huynh's Avatar
The numbers refer to the size of the valve that is used in the wastegate.
Old Sep 13, 2004 | 03:58 PM
CrazyHB's Avatar
Default Re: The difference between a 35mm , 38mm, 40mm wastegate?? (ben@importparts.com)
got ya . thx.
Old Sep 13, 2004 | 04:00 PM
02viclx's Avatar
i was going to make a thread asking this same question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">those are the sizes. the bigger the wg is the stronger it is at holding low boost with a big turbo. because it can physically bypass more exhaust gas.</TD></TR></TABLE>
so why would you use the 35mm instead of the 38mm, 38 instead of the 40mm, blah blah blah?
(im not tryin to jack your thread)
Old Sep 13, 2004 | 04:10 PM
b16sedan's Avatar
Default Re: The difference between a 35mm , 38mm, 40mm wastegate?? (02viclx)
35's are no longer being produced, 40's are a wierd step, if you want something bigger than a 38 I would just jump to a 44mm tial. A 38MM tial is good for 95% of turbo hondas, but in some cases people do get boost creep with them and move up to the 44. Chances are you only need a 38mm gate.
Boostage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02viclx &raquo;</TD></TR><TR><TD CLASS="quote">i was going to make a thread asking this same question
(im not tryin to jack your thread)</TD></TR></TABLE>
35mm is fine for low boost on a small turbo. just as an example:
10psi on a t3/t4 54 trim u would be fine with a 35mm.
10psi on a T70 u would be better of with a 40mm.
wastegate are used to lower boost not raise it, the lower the boost pressure is set the more flow the wastegate must allow. the T70 needs to bypass more exhaust than the t3/t4 to sustain that 10psi
Old Sep 13, 2004 | 04:12 PM
lanojp1's Avatar
im running a hybrid...38mm base with 40mm diaphragm..its a tial..
Old Sep 13, 2004 | 04:13 PM
CrazyHB's Avatar
Default Re: The difference between a 35mm , 38mm, 40mm wastegate?? (Boostage)
so lets say with a sc61 or a t3/t67 , 38mm , 40mm or 44mm? the 44mm seems a little too huge to me and expensive too. does it really make that BIG of a difference?
Old Sep 13, 2004 | 04:14 PM
lanojp1's Avatar
go 38...you'll be fine..
Old Sep 13, 2004 | 04:21 PM
powerls's Avatar
funny thing w/ the Tial W/G's. they 38mm, 40mm, and 44mm all have 35mm openings. And on the 44mm, the big valve is just gettting in the way.
b16sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrazyHB &raquo;</TD></TR><TR><TD CLASS="quote">so lets say with a sc61 or a t3/t67 , 38mm , 40mm or 44mm? the 44mm seems a little too huge to me and expensive too. does it really make that BIG of a difference?</TD></TR></TABLE>
The 38MM should do fine. I am running a B16 with a blox mani, SC61 with the TO4S comp housing, 3" downpipe, and the tial 38mm holds boost great, as low as 7 psi using my AVC-R.
Old Sep 13, 2004 | 04:35 PM
CrazyHB's Avatar
Default Re: (powerls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerls &raquo;</TD></TR><TR><TD CLASS="quote">funny thing w/ the Tial W/G's. they 38mm, 40mm, and 44mm all have 35mm openings. And on the 44mm, the big valve is just gettting in the way.</TD></TR></TABLE>
interesting. seems like 38mm would be best choice for the buck.
Old Sep 14, 2004 | 06:49 AM
White Smoke's Avatar
i my honda
Global Mod
The 44mm vband is a pretty nice choice
It makes it alot esear to get on and off. You have to have the vband manifold though
Old Sep 14, 2004 | 08:58 AM
rondigs's Avatar
Default Re: The difference between a 35mm , 38mm, 40mm wastegate?? (si2die4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si2die4 &raquo;</TD></TR><TR><TD CLASS="quote">The 44mm vband is a pretty nice choice
It makes it alot easier to get on and off. You have to have the vband manifold though </TD></TR></TABLE>
I concur.
I have a 60-1 hifi turbo and experienced pretty severe creep with the 38mm tial. Bought a 44mm tial... and what do ya know, no more boost creep. And BTW, Vbands rule.
Old Sep 14, 2004 | 09:00 AM
twkdCD595's Avatar
Default Re: (lanojp1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lanojp1 &raquo;</TD></TR><TR><TD CLASS="quote">im running a hybrid...38mm base with 40mm diaphragm..its a tial..</TD></TR></TABLE>
my next investment if I cannot solve my creep issues... tial calls it a high pressure 38mm I believe.
Old Sep 14, 2004 | 09:07 AM
stizzit's Avatar
Default Re: (twkdCD595)
Ima rock the 44mm just because it has vband bling!
Old Sep 14, 2004 | 09:12 AM
DIRep972's Avatar
Smarter than you
You have to go bigger when you get more efficient on the turbine or go larger on the compressor wheel. Cause both those changes cause more exhaust to exit out the wastegate w/ out passing by the turbine wheel. Basically the consequence of having too small of a wastegate is it won't allow you to lower the boost to the minimum spring pressure. Now, the question is, when do you really need to upgrade? Personally i think everyone upgrades way too early. 38mm is probably all you'd ever need on a street car unless you had a serious crazy set up. The only cars ive ever seen/heard of having wastegate problems is methanol cars. I think the different a/f ratio for lamda/stoich could have something to do with that but I am not sure.
Old Sep 14, 2004 | 09:27 AM
turbo*s2k's Avatar
Default Re: (DIRep972)
I'm running the 38mm with a 1 bar spring. Inline pro manifold no boost creep. The problem I have is I keep blowing those darn wastegate gaskets so I'm running it without one now, and I haven't had any problems. Does the 40mm or the 44mm have gaskets as well.
Old Sep 14, 2004 | 09:32 AM
DIRep972's Avatar
Smarter than you
Default Re: (TurboChrgd_Civic)
Are you running Tial gaskets? they suck. Turbonetics makes good gaskets if u need one. No gasket should fine, the carbon will seal it.
Old Sep 14, 2004 | 09:36 AM
turbo*s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">Are you running Tial gaskets? they suck. Turbonetics makes good gaskets if u need one. No gasket should be fine, the carbon will seal it. </TD></TR></TABLE>
Yes, Where can get some turbonetics gasket(s)?
Old Sep 14, 2004 | 09:48 AM
stizzit's Avatar
I don't run gaskets either and never had a leak.
Old Sep 14, 2004 | 10:05 AM
mugensport9's Avatar
ok question then lets say
d16
t3 .48/.42
15 maybe higher psi sometimes
250++whp
38 ok or should i go with 44?
Old Sep 14, 2004 | 10:07 AM
twkdCD595's Avatar
Default Re: (mugensport9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugensport9 &raquo;</TD></TR><TR><TD CLASS="quote">ok question then lets say
d16
t3 .48/.42
250++whp
38 ok or should i go with 44?</TD></TR></TABLE>
definately 38 I would think.
Old Sep 14, 2004 | 10:28 AM
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">definately 38 I would think.</TD></TR></TABLE>
2nd that
